Trying to insert a point into a polygon graphic on a time delay using setTimeout. The code works as expected if I insert the point immediately when the page loads, but if I wait three seconds nothing draws, but the data has been updated. This JSFiddle example has a function called start. When I call the function directly it works, but when I call it after a 3 seconds delay using setTimeout it does not update the graphic. Is this a bug or am I missing something?
Also, if I change the time to 700 milliseconds it works... 900 it does not. In between it works randomly.
function start() {
polylineGraphic.geometry.insertPoint(0, 0, [-112.3, 53.68]);
start(); // Works
//setTimeout(function () { start(); }, 3000); // Does not work.
