I'm using the code below to publish an image service, works fine. But I need to be able to delete the existing service before creating the new one with the same name (or alternatively I'd like to overwrite the existing one with the new one). Does anyone know the proper code to delete an image service, or else the required adjustment to have this overwrite the existing image service? Thanks!
Dan
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> os
<SPAN class="comment token"># Define local variables:</SPAN>
MDWorkspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"K:\Image Server Cache\VIMS\CCRM"</SPAN> <SPAN class="comment token"># the folder for mosaic dataset and the service defintion draft file</SPAN>
ConnectionFileWorkspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\Users\dschatt\AppData\Roaming\ESRI\Desktop10.5\ArcCatalog"</SPAN>
GdbName<SPAN class="operator token">=</SPAN><SPAN class="string token">"SCHISM_Data.gdb"</SPAN>
GDBpath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>MDWorkspace<SPAN class="punctuation token">,</SPAN>GdbName<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#File geodatabase used to store a mosaic dataset</SPAN>
Name <SPAN class="operator token">=</SPAN> <SPAN class="string token">"SCHISM_Data"</SPAN>
Md <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>GDBpath<SPAN class="punctuation token">,</SPAN> Name<SPAN class="punctuation token">)</SPAN>
Sddraft <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>MDWorkspace<SPAN class="punctuation token">,</SPAN> Name <SPAN class="operator token">+</SPAN> <SPAN class="string token">".sddraft"</SPAN><SPAN class="punctuation token">)</SPAN>
Sd <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>MDWorkspace<SPAN class="punctuation token">,</SPAN> Name <SPAN class="operator token">+</SPAN> <SPAN class="string token">".sd"</SPAN><SPAN class="punctuation token">)</SPAN>
con <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>ConnectionFileWorkspace<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"arcgis on mobjack.vims.edu_6080 (publisher).ags"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Creating SD draft"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateImageSDDraft<SPAN class="punctuation token">(</SPAN>Md<SPAN class="punctuation token">,</SPAN> Sddraft<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SCHISM_48HoursData"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ARCGIS_SERVER'</SPAN><SPAN class="punctuation token">,</SPAN> con<SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VIMS_CCRM"</SPAN><SPAN class="punctuation token">,</SPAN> None<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SCHISM, 48HoursData"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>StageService_server<SPAN class="punctuation token">(</SPAN>Sddraft<SPAN class="punctuation token">,</SPAN> Sd<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>UploadServiceDefinition_server<SPAN class="punctuation token">(</SPAN>Sd<SPAN class="punctuation token">,</SPAN> con<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Service successfully published"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
