I am using the JavaScript API version 3.16 and I am developing an application that loads three scale dependent feature layers on a map. The layers are being added to the map after the data in a column in the layer is classified via the generateRendererTask. There are feature tables associated with each layer and the appropriate feature table is visible when the corresponding feature layer is shown on the map. I have a couple questions...
1. Thanks to the code from Robert Scheitlin, the feature table updates on zoom in. On zoom out, it does not update accurately. If I change the spatial relationship to "CONTAINS" it does. Is it correct to change that parameter?
2. When the second feature layer displays, the header of the table is correct, but not the actual table results. What method should I use? I tried featureTable.grid.setStore, but that did not work.
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">http-equiv</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Content-Type<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>text/html; charset<SPAN class="punctuation token">=</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Feature Table Example For ESRI<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.16%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.16/dijit/themes/claro/claro.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.16%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.16/esri/css/esri.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.16%2F" target="_blank">https://js.arcgis.com/3.16/</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fajax.googleapis.com%2Fajax%2Flibs%2Fjquery%2F2.0.2%2Fjquery.min.js" target="_blank">https://ajax.googleapis.com/ajax/libs/jquery/2.0.2/jquery.min.js</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html, body</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="selector token">#map</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 500px<SPAN class="punctuation token">;</SPAN>
<SPAN class="selector token">#divGrid</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> 0px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN> 525px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">background-color</SPAN><SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">z-index</SPAN><SPAN class="punctuation token">:</SPAN> 999<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">overflow</SPAN><SPAN class="punctuation token">:</SPAN> scroll<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 400px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin-bottom</SPAN><SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
<SPAN class="selector token">#citypoints</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="selector token">#citypolys</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="selector token">#tractpolys</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="selector token">.displaynone</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN>
<SPAN class="selector token">#divShowHideTable</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN> 317px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">z-index</SPAN><SPAN class="punctuation token">:</SPAN> 50<SPAN class="punctuation token">;</SPAN>
<SPAN class="selector token">#imgHiddenTable:hover</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">cursor</SPAN><SPAN class="punctuation token">:</SPAN> pointer<SPAN class="punctuation token">;</SPAN>
<SPAN class="selector token">#imgShownTable:hover</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">/*#divGrid {
position: absolute;
top: 500px;
width: 100%;
height: 40%;
}*/</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token">// declare variables and instantiate some</SPAN>
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">,</SPAN> grid<SPAN class="punctuation token">,</SPAN> fl_url<SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">,</SPAN> polygonSymbol<SPAN class="punctuation token">,</SPAN> highlightSymbol<SPAN class="punctuation token">,</SPAN> pointSymbol<SPAN class="punctuation token">,</SPAN> outlineSymbol<SPAN class="punctuation token">,</SPAN> line<SPAN class="punctuation token">,</SPAN> renderer<SPAN class="punctuation token">,</SPAN> featureLayer<SPAN class="punctuation token">,</SPAN> loading<SPAN class="punctuation token">,</SPAN> myFeatureTable<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">,</SPAN> content<SPAN class="punctuation token">,</SPAN> drawingOptions<SPAN class="punctuation token">,</SPAN> placeholdertxt<SPAN class="punctuation token">,</SPAN> whereclause<SPAN class="punctuation token">,</SPAN> fieldsToDisplay<SPAN class="punctuation token">,</SPAN> selectionToolbar<SPAN class="punctuation token">,</SPAN> val<SPAN class="punctuation token">,</SPAN> fieldsoutputted<SPAN class="punctuation token">,</SPAN> fieldsarray<SPAN class="punctuation token">,</SPAN> lblgridheadertxt<SPAN class="punctuation token">,</SPAN> citypointlayer<SPAN class="punctuation token">,</SPAN> stateoutlinelayer<SPAN class="punctuation token">,</SPAN> cityoutlinelayer<SPAN class="punctuation token">,</SPAN> citypolygonlayer<SPAN class="punctuation token">,</SPAN> tractpolygonlayer<SPAN class="punctuation token">,</SPAN> citypointrenderer<SPAN class="punctuation token">,</SPAN> stateoutlinerender<SPAN class="punctuation token">,</SPAN> cityoutlinerenderer<SPAN class="punctuation token">,</SPAN> citypolygonrenderer<SPAN class="punctuation token">,</SPAN> tractpolygonrenderer<SPAN class="punctuation token">,</SPAN> tb<SPAN class="punctuation token">,</SPAN> citypointFT<SPAN class="punctuation token">,</SPAN> citypolyFT<SPAN class="punctuation token">,</SPAN> tractpolyFT<SPAN class="punctuation token">,</SPAN> rfrshtbls<SPAN class="punctuation token">,</SPAN> initld<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> visiblelayers <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
symbolArray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
labelArray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
fieldsToSearch <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> renderedField <SPAN class="operator token">=</SPAN> <SPAN class="string token">'pop2000'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> DataUnavailableTxt <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Population < 50"</SPAN><SPAN class="punctuation token">,</SPAN>
oldExtent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// initialize modules and classes</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/graphic"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Basemap"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/BasemapLayer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/BasemapGallery"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/arcgis/utils"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/urlUtils"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/webMercatorUtils"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Search"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/FeatureTable"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polygon"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ArcGISDynamicMapServiceLayer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ImageParameters"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/InfoTemplate"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/ClassBreaksRenderer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/GenerateRendererParameters"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/GenerateRendererTask"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/ClassBreaksDefinition"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/AlgorithmicColorRamp"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/lang"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/lang"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/toolbars/draw"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/geometryEngine"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/dijit/Scalebar"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/LayerDrawingOptions"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/request"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-construct"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/QueryTask"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/query"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Color"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/form/Slider"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dgrid/Selection"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/ready"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/on"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/array"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojox/gfx"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/jsonUtils"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/form/Button"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/data/ItemFileReadStore"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/registry"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/parser"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/_base/declare"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/BorderContainer"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/form/TextBox"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dgrid/extensions/ColumnHider"</SPAN>
<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map
<SPAN class="punctuation token">,</SPAN> Graphic
<SPAN class="punctuation token">,</SPAN> Basemap
<SPAN class="punctuation token">,</SPAN> BasemapLayer
<SPAN class="punctuation token">,</SPAN> BasemapGallery
<SPAN class="punctuation token">,</SPAN> arcgisUtils
<SPAN class="punctuation token">,</SPAN> urlUtils
<SPAN class="punctuation token">,</SPAN> webMercatorUtils
<SPAN class="punctuation token">,</SPAN> Search
<SPAN class="punctuation token">,</SPAN> FeatureLayer
<SPAN class="punctuation token">,</SPAN> FeatureTable
<SPAN class="punctuation token">,</SPAN> Extent
<SPAN class="punctuation token">,</SPAN> Polygon
<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol
<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer
<SPAN class="punctuation token">,</SPAN> ImageParameters
<SPAN class="punctuation token">,</SPAN> InfoTemplate
<SPAN class="punctuation token">,</SPAN> ClassBreaksRenderer
<SPAN class="punctuation token">,</SPAN> GenerateRendererParameters
<SPAN class="punctuation token">,</SPAN> GenerateRendererTask
<SPAN class="punctuation token">,</SPAN> ClassBreaksDefinition
<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol
<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol
<SPAN class="punctuation token">,</SPAN> SimpleRenderer
<SPAN class="punctuation token">,</SPAN> AlgorithmicColorRamp
<SPAN class="punctuation token">,</SPAN> esriLang
<SPAN class="punctuation token">,</SPAN> lang
<SPAN class="punctuation token">,</SPAN> Draw
<SPAN class="punctuation token">,</SPAN> Point
<SPAN class="punctuation token">,</SPAN> geometryEngine
<SPAN class="punctuation token">,</SPAN> Scalebar
<SPAN class="punctuation token">,</SPAN> LayerDrawingOptions
<SPAN class="punctuation token">,</SPAN> esriRequest
<SPAN class="punctuation token">,</SPAN> domConstruct
<SPAN class="punctuation token">,</SPAN> QueryTask
<SPAN class="punctuation token">,</SPAN> Color
<SPAN class="punctuation token">,</SPAN> Slider
<SPAN class="punctuation token">,</SPAN> domStyle
<SPAN class="punctuation token">,</SPAN> Selection
<SPAN class="punctuation token">,</SPAN> ready
<SPAN class="punctuation token">,</SPAN> on
<SPAN class="punctuation token">,</SPAN> arrayUtils
<SPAN class="punctuation token">,</SPAN> gfx
<SPAN class="punctuation token">,</SPAN> jsonUtils
<SPAN class="punctuation token">,</SPAN> Button
<SPAN class="punctuation token">,</SPAN> ItemFileReadStore
<SPAN class="punctuation token">,</SPAN> registry
<SPAN class="punctuation token">,</SPAN> parser
<SPAN class="punctuation token">,</SPAN> declare
<SPAN class="punctuation token">,</SPAN> BorderContainer
<SPAN class="punctuation token">,</SPAN> ContentPane
<SPAN class="punctuation token">,</SPAN> TextBox
<SPAN class="punctuation token">,</SPAN> ColumnHider
<SPAN class="punctuation token">)</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> DynamicMapServiceURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fsampleserver6.arcgisonline.com%2Farcgis%2Frest%2Fservices%2FUSA%2FMapServer" target="_blank">https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// define symbols</SPAN>
highlightSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setStyle</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOutline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">91</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">91</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">91</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">125</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">125</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">125</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.35</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
polygonSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleFillSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setStyle</SPAN><SPAN class="punctuation token">(</SPAN>SimpleFillSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOutline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">85</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">153</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">153</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">153</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
pointSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setStyle</SPAN><SPAN class="punctuation token">(</SPAN>SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_CIRCLE<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOutline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">85</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">153</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">153</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">153</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
outlineSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">91</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">91</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">91</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// intial map extent</SPAN>
<SPAN class="keyword token">var</SPAN> initialExtent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN>Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"xmin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">19525916.67711644</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1491562.5722065126</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"xmax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">2404022.3412415087</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymax"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9318714.26860648</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// instantiate infoTemplate</SPAN>
<SPAN class="keyword token">var</SPAN> infotemp <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// define the dynamic map service layer and the image parameter attribute it uses</SPAN>
<SPAN class="keyword token">var</SPAN> imageParameters <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ImageParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
imageParameters<SPAN class="punctuation token">.</SPAN>format <SPAN class="operator token">=</SPAN> <SPAN class="string token">"png"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> dynamicMapServiceLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"opacity"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1.0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"imageParameters"</SPAN><SPAN class="punctuation token">:</SPAN> imageParameters
<SPAN class="comment token">// add a map to the page</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//zoom: 4,</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN><SPAN class="punctuation token">,</SPAN>
extent<SPAN class="punctuation token">:</SPAN> initialExtent
<SPAN class="comment token">//,infoTemplate: infotemp</SPAN>
<SPAN class="comment token">// events that fire, based on actions in the UI</SPAN>
<SPAN class="comment token">// the function below displays an error message and hides the div in which the map is drawn</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">showErr</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN>
<SPAN class="string token">'use strict'</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error Details: "</SPAN><SPAN class="punctuation token">,</SPAN> err<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"imgShownTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// hide the table</SPAN>
<SPAN class="comment token">//ShowElement(e.id, 'divGrid', '', '');</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divGrid'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// show the hidden Legend image and hide the shown Legend image</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divShownTable'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divHiddenTable'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"imgHiddenTable"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// show the table</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divGrid'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">showHideGridAndLegend</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// hide the hidden Legend image and show the shown Legend image</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divShownTable'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#divHiddenTable'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set the initial visibility of the controls in the UI</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setInitialVisibilityOfControls</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// show buttons/controls</SPAN>
<SPAN class="comment token">//$('#divHiddenLegend').show();</SPAN>
<SPAN class="comment token">//$('#divHiddenOtherControls').show();</SPAN>
<SPAN class="comment token">//$('#divDraw').show();</SPAN>
<SPAN class="comment token">//// hide divs that contain controls</SPAN>
<SPAN class="comment token">//$('#divLegend').hide();</SPAN>
<SPAN class="comment token">//$('#divOtherControls').hide();</SPAN>
<SPAN class="comment token">// make the controls draggable</SPAN>
<SPAN class="comment token">//$("#divLegend").draggable({ containment: "#divMap", scroll: false });</SPAN>
<SPAN class="comment token">//$('#divOtherControls').draggable({ containment: "#divMap", scroll: false });</SPAN>
<SPAN class="comment token">//$('#divGrid').draggable({ containment: "#divMap", scroll: false });</SPAN>
<SPAN class="comment token">// hide the mouse-over effect (infowindow and any graphics) when the cursor moves outside of the map extent</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"mouse-out"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> loc <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>map<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">contains</SPAN><SPAN class="punctuation token">(</SPAN>loc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// substitute the "(" and ", " in the CI values</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"show"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>_contentPane<SPAN class="punctuation token">.</SPAN>innerHTML<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/\(|\)/g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/, /g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">' - '</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// clear any graphics on the map when the infowindow hides/goes away</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"hide"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//create new FeatureTable and set its properties</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">AddGrid</SPAN><SPAN class="punctuation token">(</SPAN>lyrid<SPAN class="punctuation token">,</SPAN> gridloc<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> existingGrid <SPAN class="operator token">=</SPAN> dijit<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN>gridloc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>existingGrid<SPAN class="punctuation token">)</SPAN>
existingGrid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroyRecursive</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>lyrid <SPAN class="operator token">===</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
tractpolyFT <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"featureLayer"</SPAN><SPAN class="punctuation token">:</SPAN> tractpolygonlayer<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"showStatistics"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"zoomToSelection"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"syncSelection"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"outFields"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> gridloc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>lyrid <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
citypointFT <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"featureLayer"</SPAN><SPAN class="punctuation token">:</SPAN> citypointlayer<SPAN class="punctuation token">,</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypolyFT <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"featureLayer"</SPAN><SPAN class="punctuation token">:</SPAN> citypolygonlayer<SPAN class="punctuation token">,</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// this is a custom function used to format fields in the feature table and popup</SPAN>
formatVal <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>val<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> val<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/\(|\)/g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/, /g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">' - '</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// the 3 functions below are formatting functions, with their origins documented above them</SPAN>
<SPAN class="comment token"><SPAN>//</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fstackoverflow.com%2Fquestions%2F18082%2Fvalidate-decimal-numbers-in-javascript-isnumeric%3Fpage%3D1%26amp%3Btab%3Dvotes%231830844" target="_blank">http://stackoverflow.com/questions/18082/validate-decimal-numbers-in-javascript-isnumeric?page=1&tab=votes#1830844</A></SPAN>
<SPAN class="keyword token">var</SPAN> isNumber <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>n<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="operator token">!</SPAN><SPAN class="token function">isNaN</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">parseFloat</SPAN><SPAN class="punctuation token">(</SPAN>n<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN> <SPAN class="token function">isFinite</SPAN><SPAN class="punctuation token">(</SPAN>n<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token"><SPAN>//</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fjames.padolsey.com%2Fjavascript%2Fwordwrap-for-javascript%2F" target="_blank">http://james.padolsey.com/javascript/wordwrap-for-javascript/</A></SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">wordwrap</SPAN><SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">,</SPAN> brk<SPAN class="punctuation token">,</SPAN> cut<SPAN class="punctuation token">)</SPAN>
brk <SPAN class="operator token">=</SPAN> brk <SPAN class="operator token">||</SPAN> <SPAN class="string token">'\n'</SPAN><SPAN class="punctuation token">;</SPAN>
width <SPAN class="operator token">=</SPAN> width <SPAN class="operator token">||</SPAN> <SPAN class="number token">75</SPAN><SPAN class="punctuation token">;</SPAN>
cut <SPAN class="operator token">=</SPAN> cut <SPAN class="operator token">||</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>str<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> str<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> regex <SPAN class="operator token">=</SPAN> <SPAN class="string token">'.{1,'</SPAN> <SPAN class="operator token">+</SPAN> width <SPAN class="operator token">+</SPAN> <SPAN class="string token">'}(\\s|$)'</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>cut <SPAN class="operator token">?</SPAN> <SPAN class="string token">'|.{'</SPAN> <SPAN class="operator token">+</SPAN> width <SPAN class="operator token">+</SPAN> <SPAN class="string token">'}|.+$'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'|\\S+?(\\s|$)'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//this line will cause a JSLint error: Missing 'new' prefix when invoking a constructor (this error can be ignored)</SPAN>
<SPAN class="keyword token">return</SPAN> str<SPAN class="punctuation token">.</SPAN><SPAN class="token function">match</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">RegExp</SPAN><SPAN class="punctuation token">(</SPAN>regex<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'g'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">join</SPAN><SPAN class="punctuation token">(</SPAN>brk<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">formatValues</SPAN><SPAN class="punctuation token">(</SPAN>num<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> number<SPAN class="punctuation token">.</SPAN><SPAN class="token function">format</SPAN><SPAN class="punctuation token">(</SPAN>num<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"places"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="comment token">// this function is a modification of the one just above</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">formatValues2</SPAN><SPAN class="punctuation token">(</SPAN>num<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> num <SPAN class="operator token">=</SPAN> num<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toFixed</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// the functions below dynamically generate a renderer and apply that</SPAN>
<SPAN class="comment token">// renderer generated by the createRenderer function above to the featureLayer and adds labels.</SPAN>
<SPAN class="comment token">// using individual functions, as trying to use a generic/parameterized one before did not work</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">applyctyptRenderer</SPAN><SPAN class="punctuation token">(</SPAN>citypointrenderer<SPAN class="punctuation token">)</SPAN>
citypointrenderer<SPAN class="punctuation token">.</SPAN>defaultLabel <SPAN class="operator token">=</SPAN> DataUnavailableTxt<SPAN class="punctuation token">;</SPAN>
citypointrenderer<SPAN class="punctuation token">.</SPAN>defaultSymbol <SPAN class="operator token">=</SPAN> pointSymbol<SPAN class="punctuation token">;</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>citypointrenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN>renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOpacityInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0.7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>citypointlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">applystoutRenderer</SPAN><SPAN class="punctuation token">(</SPAN>stateoutlinerenderer<SPAN class="punctuation token">)</SPAN>
stateoutlinerenderer<SPAN class="punctuation token">.</SPAN>defaultLabel <SPAN class="operator token">=</SPAN> DataUnavailableTxt<SPAN class="punctuation token">;</SPAN>
stateoutlinerenderer<SPAN class="punctuation token">.</SPAN>defaultSymbol <SPAN class="operator token">=</SPAN> outlineSymbol<SPAN class="punctuation token">;</SPAN>
stateoutlinelayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>stateoutlinerenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>stateoutlinelayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">applyctyoutRenderer</SPAN><SPAN class="punctuation token">(</SPAN>cityoutlinerenderer<SPAN class="punctuation token">)</SPAN>
cityoutlinerenderer<SPAN class="punctuation token">.</SPAN>defaultLabel <SPAN class="operator token">=</SPAN> DataUnavailableTxt<SPAN class="punctuation token">;</SPAN>
cityoutlinerenderer<SPAN class="punctuation token">.</SPAN>defaultSymbol <SPAN class="operator token">=</SPAN> outlineSymbol<SPAN class="punctuation token">;</SPAN>
cityoutlinelayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>cityoutlinerenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>cityoutlinelayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">applyctypolyRenderer</SPAN><SPAN class="punctuation token">(</SPAN>citypolygonrenderer<SPAN class="punctuation token">)</SPAN>
citypolygonrenderer<SPAN class="punctuation token">.</SPAN>defaultLabel <SPAN class="operator token">=</SPAN> DataUnavailableTxt<SPAN class="punctuation token">;</SPAN>
citypolygonrenderer<SPAN class="punctuation token">.</SPAN>defaultSymbol <SPAN class="operator token">=</SPAN> polygonSymbol<SPAN class="punctuation token">;</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>citypolygonrenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN>renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOpacityInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0.7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>citypolygonlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">applytrtpolyRenderer</SPAN><SPAN class="punctuation token">(</SPAN>tractpolygonrenderer<SPAN class="punctuation token">)</SPAN>
tractpolygonrenderer<SPAN class="punctuation token">.</SPAN>defaultLabel <SPAN class="operator token">=</SPAN> DataUnavailableTxt<SPAN class="punctuation token">;</SPAN>
tractpolygonrenderer<SPAN class="punctuation token">.</SPAN>defaultSymbol <SPAN class="operator token">=</SPAN> polygonSymbol<SPAN class="punctuation token">;</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>tractpolygonrenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN>renderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOpacityInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0.7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>tractpolygonlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createRenderer</SPAN><SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> classDef <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClassBreaksDefinition</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>classificationField <SPAN class="operator token">=</SPAN> field<SPAN class="punctuation token">;</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>classificationMethod <SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islClassifiers'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islClassifiers'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"natural-breaks"</SPAN><SPAN class="punctuation token">;</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>breakCount <SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islClassifiersCount'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islClassifiersCount'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>baseSymbol <SPAN class="operator token">=</SPAN> pointSymbol<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">:</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>baseSymbol <SPAN class="operator token">=</SPAN> polygonSymbol<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">default</SPAN><SPAN class="punctuation token">:</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>baseSymbol <SPAN class="operator token">=</SPAN> outlineSymbol<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> colorRamp <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">AlgorithmicColorRamp</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islColorScheme'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'OriginalBlue'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">// original that we use on BRFSS</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>fromColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#F0F9E8"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>toColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#2b8cbe"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'Prevention'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">// default color scheme for prevention</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>fromColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#ffffcc"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>toColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#0c2c84"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'UnhealthyBehaviors'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">// default color scheme for unhealthy behaviors and healthy outcomes</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>fromColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#ffffd4"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>toColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#8c2d04"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'HealthyOutcomes'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">'Orange'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">// another option -- orange-ish</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>fromColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#ffffe5"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>toColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#662506"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// another option -- blue-ish</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>fromColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#ffffd9"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>toColor <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color<SPAN class="punctuation token">.</SPAN>fromHex</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#081d58"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
colorRamp<SPAN class="punctuation token">.</SPAN>algorithm <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hsv"</SPAN><SPAN class="punctuation token">;</SPAN>
classDef<SPAN class="punctuation token">.</SPAN>colorRamp <SPAN class="operator token">=</SPAN> colorRamp<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GenerateRendererParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>classificationDefinition <SPAN class="operator token">=</SPAN> classDef<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> whereclause<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> generateRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GenerateRendererTask</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN> lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// apply a different renderer, based on the layer</SPAN>
generateRenderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> applyctyptRenderer<SPAN class="punctuation token">,</SPAN> showErr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
generateRenderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> applyctypolyRenderer<SPAN class="punctuation token">,</SPAN> showErr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
generateRenderer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> applytrtpolyRenderer<SPAN class="punctuation token">,</SPAN> showErr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// show the attributes in a custom way</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">showCustomIW</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">,</SPAN> lyrid<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> e<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">setIWTitleAndContent</SPAN><SPAN class="punctuation token">(</SPAN>lyrid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN>esriLang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">substitute</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">,</SPAN> infotemp<SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>esriLang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">substitute</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">,</SPAN> infotemp<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
lyrid <SPAN class="operator token">===</SPAN> <SPAN class="string token">'0'</SPAN> <SPAN class="operator token">||</SPAN> lyrid <SPAN class="operator token">===</SPAN> <SPAN class="string token">'2'</SPAN> <SPAN class="operator token">?</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">350</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">250</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">350</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">150</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> highlightGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN> lyrid <SPAN class="operator token">===</SPAN> <SPAN class="string token">'0'</SPAN> <SPAN class="operator token">?</SPAN> pointSymbol <SPAN class="punctuation token">:</SPAN> polygonSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>highlightGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInfoWindowAnchor</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// hide the infowindow and any graphics</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">hideInfoWindow</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// set title and content of infowindow</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setIWTitleAndContent</SPAN><SPAN class="punctuation token">(</SPAN>layerid<SPAN class="punctuation token">)</SPAN>
title <SPAN class="operator token">=</SPAN> <SPAN class="string token">"${areaname}"</SPAN><SPAN class="punctuation token">;</SPAN>
content <SPAN class="operator token">=</SPAN> <SPAN class="string token">"${*}"</SPAN><SPAN class="punctuation token">;</SPAN>
infotemp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN>title<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
infotemp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>content<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">LoadCityPointLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//#region CityPointLayer</SPAN>
<SPAN class="comment token">// add city point layer</SPAN>
citypointlayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/0"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_ONDEMAND<SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//infoTemplate: infotemp,</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"City Point Layer"</SPAN><SPAN class="punctuation token">,</SPAN>
minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4622324</SPAN>
<SPAN class="token function">createRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> renderedField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//citypointlayer.on("click", function(evt)</SPAN>
<SPAN class="comment token">//{</SPAN>
<SPAN class="comment token">// showCustomIW(evt, 0);</SPAN>
<SPAN class="comment token">//});</SPAN>
<SPAN class="comment token">//citypointlayer.on("mouse-over", function(evt)</SPAN>
<SPAN class="comment token">//citypointlayer.on("mouse-out", hideInfoWindow);</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> results <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN>
results<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>OBJECTID<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN>selectedRowIds <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">;</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">_showSelectedRecords</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN>_gridTitleNode<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> citypointlayer<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">' ('</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">!=</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">?</SPAN> results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Features)'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Feature)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-clear"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSelectionSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">AddGrid</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"citypoints"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// limit the feature table to the records of the feature layer in the current map extent</SPAN>
<SPAN class="comment token">// sort, as well</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'sort'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
attribute<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"NAME"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> extent <SPAN class="operator token">=</SPAN> citypointlayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">canProject</SPAN><SPAN class="punctuation token">(</SPAN>extent<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"extent-change"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// do not highlight the features when the map extent changes, as can be seen from below...it triggers a selection</SPAN>
<SPAN class="comment token"><SPAN>// taken from </SPAN><A class="jive-link-thread-small" data-containerid="2128" data-containertype="14" data-objectid="173929" data-objecttype="1" href="https://community.esri.com/thread/173929" target="_blank">https://community.esri.com/thread/173929</A></SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> params<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>spatialRelationship <SPAN class="operator token">=</SPAN> Query<SPAN class="punctuation token">.</SPAN>SPATIAL_REL_INTERSECTS<SPAN class="punctuation token">;</SPAN>
citypointlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>SELECTION_NEW<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//#endregion</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">LoadCityPolygonLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//#region CityPolygonLayer</SPAN>
<SPAN class="comment token">// add city polygon layer</SPAN>
citypolygonlayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"City Polygon Layer"</SPAN><SPAN class="punctuation token">,</SPAN>
minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4622324</SPAN><SPAN class="punctuation token">,</SPAN>
maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1155581</SPAN>
<SPAN class="token function">createRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> renderedField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//citypolygonlayer.on("click", function(evt)</SPAN>
<SPAN class="comment token">// showCustomIW(evt, 2);</SPAN>
<SPAN class="comment token">//citypolygonlayer.on("mouse-over", function(evt)</SPAN>
<SPAN class="comment token">//citypolygonlayer.on("mouse-out", hideInfoWindow);</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN>selectedRowIds <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">;</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">_showSelectedRecords</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN>_gridTitleNode<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> citypolygonlayer<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">' ('</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">!=</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">?</SPAN> results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Features)'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Feature)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-clear"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSelectionSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">AddGrid</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"citypolys"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'sort'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> extent <SPAN class="operator token">=</SPAN> citypolygonlayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">;</SPAN>
citypolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>SELECTION_NEW<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">LoadTractPolygonLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//#region TractPolygonLayer</SPAN>
<SPAN class="comment token">// add census tract polygon layer</SPAN>
tractpolygonlayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Census Tract Polygon Layer"</SPAN><SPAN class="punctuation token">,</SPAN>
minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1155581</SPAN><SPAN class="punctuation token">,</SPAN>
maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="token function">createRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> renderedField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//tractpolygonlayer.on("click", function(evt)</SPAN>
<SPAN class="comment token">// showCustomIW(evt, 3);</SPAN>
<SPAN class="comment token">//tractpolygonlayer.on("mouse-over", function(evt)</SPAN>
<SPAN class="comment token">//tractpolygonlayer.on("mouse-out", hideInfoWindow);</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN>selectedRowIds <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">;</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN><SPAN class="token function">_showSelectedRecords</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN>_gridTitleNode<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> tractpolygonlayer<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">' ('</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">!=</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">?</SPAN> results<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Features)'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">' Feature)'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-clear"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setSelectionSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">AddGrid</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"tractpolys"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'sort'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
attribute<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"plc_tract2010"</SPAN>
<SPAN class="keyword token">var</SPAN> extent <SPAN class="operator token">=</SPAN> tractpolygonlayer<SPAN class="punctuation token">.</SPAN>fullExtent<SPAN class="punctuation token">;</SPAN>
tractpolygonlayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>SELECTION_NEW<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// the function below shows/hides the appropriate feature table, based on the map scale</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">showHideGridAndLegend</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="string token">'use strict'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//console.log(map.getScale());</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getScale</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">>=</SPAN> <SPAN class="number token">4622324</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#citypoints'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#citypolys'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#tractpolys'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// the feature table is sometimes not shown expanded when the window showing it opens</SPAN>
<SPAN class="comment token">// a search online led me to a post that recommended re-sizing the table, after the window has been opened</SPAN>
<SPAN class="comment token">// this is an attempt that only works occasionally, right now</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>citypointFT<SPAN class="punctuation token">)</SPAN>
citypointFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getScale</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><</SPAN> <SPAN class="number token">4622324</SPAN> <SPAN class="operator token">&&</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getScale</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">></SPAN> <SPAN class="number token">1155581</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#citypoints'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#citypolys'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>citypolyFT<SPAN class="punctuation token">)</SPAN>
citypolyFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getScale</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token"><=</SPAN> <SPAN class="number token">1155581</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#tractpolys'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>tractpolyFT<SPAN class="punctuation token">)</SPAN>
tractpolyFT<SPAN class="punctuation token">.</SPAN>grid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// the function below zooms to the map extent of the results of a query</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getMapExtentOnZoom</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// without the delays in calling the functions below, the functionality was not consistent.</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">&&</SPAN> <SPAN class="keyword token">typeof</SPAN> result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="string token">'undefined'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//map.setExtent(result.features[0].geometry.getExtent().expand(1.45));</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getExtent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">450</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>initialExtent<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//showHideGridAndLegend();</SPAN>
<SPAN class="comment token">// the function below queries the feature layer, based on if the where clause has a value or not</SPAN>
<SPAN class="comment token">// if it does not, it uses the current map extent/geometry to limit the feature layer query</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">zoomToSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> loc<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set the layer to use, based on the selected input controls --</SPAN>
<SPAN class="comment token">// States for City data and City polygons for Census data</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islCities'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">&&</SPAN> <SPAN class="keyword token">typeof</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islCities'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="string token">'undefined'</SPAN><SPAN class="punctuation token">)</SPAN>
loc <SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islCities'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
idx <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
loc <SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islStates'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">===</SPAN> <SPAN class="string token">'59'</SPAN> <SPAN class="operator token">?</SPAN> <SPAN class="string token">'1=1'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#islStates'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
idx <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">typeof</SPAN> <SPAN class="punctuation token">(</SPAN>loc<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="string token">'undefined'</SPAN> <SPAN class="operator token">&&</SPAN> loc<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// define the field to query to get the extent to show on zoom To</SPAN>
<SPAN class="keyword token">var</SPAN> qryfield <SPAN class="operator token">=</SPAN> loc<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// assigning the spatial reference here, once the map is already created</SPAN>
<SPAN class="keyword token">var</SPAN> qry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
qry<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>SpatialReference<SPAN class="punctuation token">;</SPAN>
qry<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>idx <SPAN class="operator token">===</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
qry<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"STPL_FIPS = '"</SPAN> <SPAN class="operator token">+</SPAN> qryfield <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
qry<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"STATE = '"</SPAN> <SPAN class="operator token">+</SPAN> qryfield <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
qry<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> qry<SPAN class="punctuation token">.</SPAN>where<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/'/g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"QUOTE"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> qryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN>DynamicMapServiceURL <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN> idx<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
qryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>qry<SPAN class="punctuation token">,</SPAN> getMapExtentOnZoom<SPAN class="punctuation token">,</SPAN> showErr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// function that calls individual functions to load the layers and tables and zoom, if necessary</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">LoadLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//renderedField = $('#islMeasures option:selected').val() !== '' && typeof $('#islMeasures option:selected').val() !== 'undefined' ? $('#islMeasures option:selected').val() + "_CrudePrev" : 'BINGE_CrudePrev';</SPAN>
<SPAN class="comment token">//CI = $('#islMeasures option:selected').val() !== '' && typeof $('#islMeasures option:selected').val() !== 'undefined' ? $('#islMeasures option:selected').val() + "_Crude95CI" : "BINGE_Crude95CI";</SPAN>
renderedField <SPAN class="operator token">=</SPAN> <SPAN class="string token">'pop2000'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">LoadCityPointLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">LoadCityPolygonLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">LoadTractPolygonLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//LoadStateOutlineAndCityBoundaryLayers();</SPAN>
<SPAN class="comment token">// add drawing toolbox</SPAN>
<SPAN class="comment token">//addDrawingTools();</SPAN>
<SPAN class="comment token">// remove layers from the map</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">RemoveLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeLayer</SPAN><SPAN class="punctuation token">(</SPAN>citypointlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeLayer</SPAN><SPAN class="punctuation token">(</SPAN>citypolygonlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeLayer</SPAN><SPAN class="punctuation token">(</SPAN>tractpolygonlayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//map.removeLayer(dynamicMapServiceLayer);</SPAN>
<SPAN class="comment token">// load the feature layers when the map loads</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// add feature layers to the map and associated behaviors of feature layers</SPAN>
<SPAN class="token function">LoadLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set initil visibility of buttons/divs/etc.</SPAN>
<SPAN class="token function">setInitialVisibilityOfControls</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// determine which feature table to show when a user zooms</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"extent-change"</SPAN><SPAN class="punctuation token">,</SPAN> showHideGridAndLegend<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>claro esri<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">data-dojo-type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>dijit/layout/BorderContainer<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">data-dojo-props</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>design:<SPAN class="punctuation token">'</SPAN>headline<SPAN class="punctuation token">'</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">="</SPAN><SPAN class="attr-value token"><SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN></SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">data-dojo-type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>dijit/layout/ContentPane<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">data-dojo-props</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>region:<SPAN class="punctuation token">'</SPAN>center<SPAN class="punctuation token">'</SPAN>, splitter:true<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"> <SPAN class="attr-name token">style</SPAN></SPAN><SPAN class="punctuation token">="</SPAN><SPAN class="attr-value token"><SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>50%</SPAN><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>map<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>divShowHideTable<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>divShownTable<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>displaynone<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">alttext</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Image that displays when the Feature Table is showing.<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Shared.Images.table_selected.png<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>imgShownTable<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">tooltip</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Hide Table<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>divHiddenTable<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>displaynone<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>img</SPAN> <SPAN class="attr-name token">alttext</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Image that displays when the Feature Table is hidden.<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Shared.Images.table_default.png<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>imgHiddenTable<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">tooltip</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Show Table<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>divGrid<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>citypoints<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>citypolys<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>tractpolys<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any help is greatly appreciated. Thanks.
- Chris
