Hi All,I have a script which pulls information from a number of XML files to populate a table within a HTML document.Although I can pull the information, it is overwriting the table space with the new information. What I would like to do is append the table space (body) of the HTML document for each new XML file, so that I will have a Thumbnail, metadata details for each XML creating a large HTML listing of data for quick reference.import arcpy, sys import xml.etree.ElementTree as ET html_head = """ <!DOCTYPE HTML> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title></title> </head>""" fh = open(r'D:\Temp\CSD_HTML\file.html', 'wb') fh.write(html_head) XML_List = [r'D:\Temp\CSD_HTML\test.xml', r'D:\Temp\CSD_HTML\contours.sdc.xml'] for xml in XML_List: print xml + '\n' path = xml tree = ET.parse(path) for node in tree.findall('.//title'): title = node.text print 'Title: ' + node.text for node in tree.findall('.//westbc'): westbc = node.text print 'West: ' + node.text for node in tree.findall('.//eastbc'): eastbc = node.text print 'East: ' + node.text for node in tree.findall('.//northbc'): northbc = node.text print 'North: ' + node.text for node in tree.findall('.//southbc'): southbc = node.text print 'South: ' + node.text for node in tree.findall('.//geogunit'): geogunit = node.text print 'Geographic Units: ' + node.text for node in tree.findall('.//horizdn'): horizdn = node.text print 'Projection: ' + node.text for node in tree.findall('.//ellips'): ellips = node.text print 'Ellipsoid: ' + node.text html_body = """ <body> <p> </p> <table width="800" border="0"> <tr> <td width="309" rowspan="5"><img src="Thumbs/MitchellD_2013-06-25.jpg" alt="" width="300" height="300" align="left"></td> <td width="4" rowspan="5"> </td> <td height="50" colspan="3">Title: """ + title + """</td> </tr> <tr> <td width="150" height="50"> </td> <td width="165" height="50">North: """ + northbc + """</td> <td width="150" height="50"> </td> </tr> <tr> <td height="50">West: """ + westbc + """</td> <td height="50"> </td> <td height="50">East: """ + eastbc + """</td> </tr> <tr> <td height="50"> </td> <td height="50">South: """ + southbc + """</td> <td height="50"> </td> </tr> <tr> <td height="150" colspan="3"><p>Geographic Units: """ + geogunit + """</p> <p>Projection: """ + horizdn + """</p> <p>Ellipsoid: """ + ellips + """</p></td> </tr> </table> <p> </p> </body>""" fh = open(r'D:\Temp\CSD_HTML\file.html', 'a+') fh.write(html_body) html_tail = """ </html>""" fh = open(r'D:\Temp\CSD_HTML\file.html', 'wb') fh.write(html_tail) fh.close() del tree Having an issue getting subsequent tables to add to HTML with each metadata details for each XML file.Regards,Craig
