I recently started development of an app using ArcGIS Runtime dot net SDK (WPF). I have an issue related to the the elevation offset for scene layer package (slpk).
When I load my slpk layer to ArcGIS Online it overlays above the ground. but in ArcGIS Online I can set the elevation offset that corrects the vertical position of the model.
Now if I use the portal item or ArcGIS Online service in dot net WPF app it works fine because my model has been published with an offset.
But i want to load my slpk file local path, and I am unable to find any such option to set the offset value for ground overlay.
#Uri _serviceUri = new System.Uri(@"D:\Projects\test\lod75.slpk"); ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer(_serviceUri); myScene.OperationalLayers.Add(sceneLayer);
