We are tying to upload attachments using featureLayer.addAttachment operation.
We are using ArcGIS javascript API 3.8 and Emberjs.
Note: We do not have a proxy for our ArcGIS server.
// The proxy url you see does not work.
is it necessary to use a proxy? Can we do without it.
Here is the code
file.hbs
<div class="form-group">
<div class="col-sm-12 col-md-7 col-lg-7">
<form id="myForm">
<div class="col-sm-8"> <input type="file" name="attachment" /></div>
<div class="col-sm-4"> <button class="btn btn-success" type="submit" id="upload"
{{action "addAttachments" }}>Submit</button></div>
</form>
</div>
</div>file_controller.js
addAttachments:function(){
var controller = this;
require([
'esri/layers/FeatureLayer'
function (
FeatureLayer
esri.config.defaults.io.proxyUrl = "https://mapviewtest.memphistn.gov/proxy/proxy.ashx";
esri.config.defaults.io.alwaysUseProxy = false;
var objId = controller.get('projObjectId');
var attchUrl = App.Config.services.pmsPhotoService + objId;
var featureLayer = new FeatureLayer(attchUrl);
var form = document.getElementById("myForm");
featureLayer.addAttachment(objId, form ,callback , function(err){
console.log(err);
function callback(result){
console.log(result);
},Here is the log of console with all variables and err message and snap of the same log.
our attachment url has no problem.
Here is the console log
objId
18015
attchUrl
"https://mapviewtest.memphistn.gov/arcgis/rest/services/AGO_GeneralServices/PMS_WOMS/FeatureServer/1/18015"
<form id="myForm"><div class="col-sm-8"><input type="file" name="attachment"></div><div class="col-sm-4">…</div></form>
dev.html#/projectDashBoard:1 Access to XMLHttpRequest at 'https://mapviewtest.memphistn.gov/proxy/proxy.ashx?https://mapviewtest.memphistn.gov/arcgis/rest/services/AGO_GeneralServices/PMS_WOMS/FeatureServer/1/18015/18015/addAttachment' from origin 'http://localhost:9876' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
init.js:187 r {message: "Unable to load https://mapviewtest.memphistn.gov/p…atureServer/1/18015/18015/addAttachment status: 0", response: {…}, status: 0, responseText: "", xhr: XMLHttpRequest, …}
w @ init.js:187
(anonymous) @ init.js:186
c @ init.js:74
d @ init.js:74
resolve.callback @ init.js:75
c @ init.js:74
d @ init.js:74
reject.errback @ init.js:76
c @ init.js:74
d @ init.js:74
c @ init.js:74
d @ init.js:74
(anonymous) @ init.js:190
f @ init.js:194
q @ init.js:194
w.reject @ init.js:197
a @ init.js:195
f @ init.js:195
q @ init.js:194
a @ init.js:195
f @ init.js:195
q @ init.js:194
a @ init.js:195
f @ init.js:195
q @ init.js:194
a @ init.js:195
f @ init.js:195
q @ init.js:194
r @ init.js:156
h @ init.js:160
error (async)
d @ init.js:160
f @ init.js:157
b.xhr @ init.js:190
b.rawXhrPost.b.xhrPost @ init.js:191
v @ init.js:466
d @ init.js:468
B @ init.js:473
_sendAttachment @ FeatureLayer.js:86
addAttachment @ FeatureLayer.js:55
(anonymous) @ app/controllers/projectDashBoard_controller.js:779
ga @ init.js:32
(anonymous) @ init.js:24
ha @ init.js:32
Ma @ init.js:24
p @ init.js:15
addAttachments @ app/controllers/projectDashBoard_controller.js:766
send @ lib-dev.js:34902
(anonymous) @ lib-dev.js:53661
run @ lib-dev.js:24306
Ember.run @ lib-dev.js:24685
handler @ lib-dev.js:53659
(anonymous) @ lib-dev.js:38415
Ember.handleErrors @ lib-dev.js:19257
(anonymous) @ lib-dev.js:38407
dispatch @ lib-dev.js:9009
elemData.handle @ lib-dev.js:8685
Show 6 more frames
err
r {message: "Unable to load https://mapviewtest.memphistn.gov/p…atureServer/1/18015/18015/addAttachment status: 0", response: {…}, status: 0, responseText: "", xhr: XMLHttpRequest, …}log: undefinedmessage: "Unable to load https://mapviewtest.memphistn.gov/proxy/proxy.ashx?https://mapviewtest.memphistn.gov/arcgis/rest/services/AGO_GeneralServices/PMS_WOMS/FeatureServer/1/18015/18015/addAttachment status: 0"response: {url: "https://mapviewtest.memphistn.gov/proxy/proxy.ashx…MS_WOMS/FeatureServer/1/18015/18015/addAttachment", options: a, getHeader: ƒ, xhr: XMLHttpRequest, status: 0, …}responseText: ""status: 0xhr: XMLHttpRequest {onreadystatechange: null, readyState: 0, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}_ssl: undefinedstack: "Error: Unable to load https://mapviewtest.memphistn.gov/proxy/proxy.ashx?https://mapviewtest.memphistn.gov/arcgis/rest/services/AGO_GeneralServices/PMS_WOMS/FeatureServer/1/18015/18015/addAttachment status: 0↵ at new r (http://js.arcgis.com/3.8compact/init.js:221:367)↵ at XMLHttpRequest.h (http://js.arcgis.com/3.8compact/init.js:160:167)"__proto__: Error
