I have a python toolbox that I want to publish as a geoprocessing service, the problem is I can't set the geometry type of the output so it's failing when I try to use it as a GP service. Does anyone know how to set the geometry type of a python toolbox out put? Tool was published from arcmap 10.6, running on arcserver 10.5.
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> os
<SPAN class="comment token"># Tool initialization</SPAN>
<SPAN class="comment token">#-----------------------------------------------------------------------------</SPAN>
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Toolbox</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Value_Extraction_Tool"</SPAN>
self<SPAN class="punctuation token">.</SPAN>alias <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Value Extraction Tool"</SPAN>
<SPAN class="comment token"># List of tool classes associated with this toolbox</SPAN>
self<SPAN class="punctuation token">.</SPAN>tools <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>Tool<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Tool</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#Define the tool (tool name is the name of the class)</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Value Extraction Tool"</SPAN>
self<SPAN class="punctuation token">.</SPAN>description <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>
self<SPAN class="punctuation token">.</SPAN>canRunInBackground <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getParameterInfo</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
DataSource <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">"DataSource"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"DataSource"</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">"DEWorkspace"</SPAN><SPAN class="punctuation token">,</SPAN>
parameterType<SPAN class="operator token">=</SPAN><SPAN class="string token">"Required"</SPAN><SPAN class="punctuation token">,</SPAN>
direction<SPAN class="operator token">=</SPAN><SPAN class="string token">"Input"</SPAN><SPAN class="punctuation token">)</SPAN>
InputPoint <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">"InputPoint"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"InputPoint"</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">"DEFeatureClass"</SPAN><SPAN class="punctuation token">,</SPAN>
OutputFC <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">"OutputFC"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"OutputFC"</SPAN><SPAN class="punctuation token">,</SPAN>
parameterType<SPAN class="operator token">=</SPAN><SPAN class="string token">"Output"</SPAN><SPAN class="punctuation token">,</SPAN>
direction<SPAN class="operator token">=</SPAN><SPAN class="string token">"Output"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#OutputFC.schema.geometryType = "Point"</SPAN>
params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>DataSource<SPAN class="punctuation token">,</SPAN> InputPoint<SPAN class="punctuation token">,</SPAN> OutputFC<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">return</SPAN> params
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">isLicensed</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Set whether tool is licensed to execute.</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateParameters</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Modify the values and properties of parameters before internal validation is performed. </SPAN>
<SPAN class="comment token"># This method is called whenever a parameter has been changed.</SPAN>
parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>schema<SPAN class="punctuation token">.</SPAN>geometryType <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Point"</SPAN>
parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>schema<SPAN class="punctuation token">.</SPAN>geometryTypeRule <SPAN class="operator token">=</SPAN> <SPAN class="string token">"As Specified"</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateMessages</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#Modify the messages created by internal validation for each tool</SPAN>
<SPAN class="comment token">#parameter. This method is called after internal validation.</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">,</SPAN> messages<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token"># User input arguments</SPAN>
DataSource <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
InputPoint <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
OutputFC <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
<SPAN class="comment token"># Handle all input point procesing</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN>InputPoint<SPAN class="punctuation token">,</SPAN> OutputFC<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Add fields to hold temporal data</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>OutputFC<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LABEL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>OutputFC<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VALUE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Loop through geometry attributes and get the x and y</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>InputPoint<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@X'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SHAPE@Y'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
PointIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
X <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
Y <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># Get rasters and extract data at an X and Y </SPAN>
index <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">,</SPAN> dirs<SPAN class="punctuation token">,</SPAN> files<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">in</SPAN> os<SPAN class="punctuation token">.</SPAN>walk<SPAN class="punctuation token">(</SPAN>DataSource<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> ThisFile <SPAN class="keyword token">in</SPAN> files<SPAN class="punctuation token">:</SPAN>
fName<SPAN class="punctuation token">,</SPAN>fExt <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>splitext<SPAN class="punctuation token">(</SPAN>ThisFile<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> fExt<SPAN class="punctuation token">.</SPAN>upper<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">".IMG"</SPAN> <SPAN class="operator token">or</SPAN> fExt<SPAN class="punctuation token">.</SPAN>upper<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">".TIF"</SPAN><SPAN class="punctuation token">:</SPAN>
RasterPath <SPAN class="operator token">=</SPAN> path <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> ThisFile
data <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetCellValue_management<SPAN class="punctuation token">(</SPAN>RasterPath<SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>X<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>Y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>getOutput<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
aquisition_date <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN>in_raster <SPAN class="operator token">=</SPAN> RasterPath<SPAN class="punctuation token">,</SPAN> property_type <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ACQUISITIONDATE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> str<SPAN class="punctuation token">(</SPAN>aquisition_date<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>upper<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"UNKNOWN"</SPAN><SPAN class="punctuation token">:</SPAN>
insertcursor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>OutputFC<SPAN class="punctuation token">)</SPAN>
row <SPAN class="operator token">=</SPAN> insertcursor<SPAN class="punctuation token">.</SPAN>newRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
row<SPAN class="punctuation token">.</SPAN>setValue<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LABEL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"{}, Point: {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>index<SPAN class="punctuation token">,</SPAN> PointIndex<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> data<SPAN class="punctuation token">.</SPAN>isdigit<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">.</SPAN>setValue<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"VALUE"</SPAN><SPAN class="punctuation token">,</SPAN> int<SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
insertcursor<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> insertcursor
index <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN>
PointIndex <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Here is the results of when I publish it
Task: Value Extraction Tool
Display Name: Value Extraction Tool
Description:
Category:
Help URL: https://localhost:6443/arcgis/rest/directories/arcgisoutput/Test/WA_VE_Tool_GPServer/Test_WA_VE_Tool/Tool.htm
Execution Type: esriExecutionTypeAsynchronous
Parameters:
Parameter: InputPoint
Data Type: GPFeatureRecordSetLayer
Display Name InputPoint
Description: ESRS
Direction: esriGPParameterDirectionInput
Default Value:
Geometry Type: esriGeometryPoint
HasZ: false
HasM: false
Spatial Reference: 4326 (4326)
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
Features: None.
Parameter Type: esriGPParameterTypeRequired
Category:
Parameter: OutputFC
Display Name OutputFC
Description: ESRS
Direction: esriGPParameterDirectionOutput
Default Value:
Geometry Type:
HasZ: false
HasM: false
Spatial Reference: N/A
Fields: None
Features: None.
Category: <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
