The initial goal is to show a problem of a symbol of the AdvancedSymbology.
Therefore i create a map and add 2 graphicalOverlays.
A DictionaryRenderer is assigned to the second graphicalOverlay.
While i was building the sample i moved two statements, leading to a reproducable crash (Windows and Linux)
- approach: add the 2 graphicalOverlays to the model immediately after they are created.
- approach: add the 2 graphicalOverlays to the model after the graphics are added the the graphicalOverlays.
This happens using the RenderingMode::Dynamic, not with Static.
I added a complete example (Winzip can process tgz files)
Compile, Link, Run and press "Symbol Failure" -> coredump
(look at define LETS_CRASH)
Can someone please verify?
Thank you very much
