Hey all,
Relatively new to ArcGIS Pro, so apologies there is anything I am missing!
I am uploading a batch of raster images to ArcGIS and working through the georeferencing process. For each image, I have several points that i have X, Y coordinates for. I can manually add control points using the Locate function and these coordinates. However, due to the volume of images I'm hoping to process, I was trying to figure out the Import Control Points feature, but each time I try to do this, the upload fails.
Right now, the Import Points file I have is a text file in the format:
- (Point Name, X Position on Image, Y Position on Image, Northing Coordinate on Map, Easting Coordinate on Map
Where I have converted the XY coordinates to the State Plane Coordinate System (see below):
1 114.453 296.689 2229763.827 1403851.607
2 172.235 613.380 2196755.759 1385682.876
However, this keeps failing import and/or failing to import correctly. Is there a different way I should be formatting this? What is the best way to import control points using XY coordinates within ArcGIS Pro?
Thanks!
Meg
#importcontrolpoints #importerror #arcgispro #georeferencing
