Hi Everyone,
i'm struggling with this problem.
Have developed a simple base map application in WPF using .NET Runtime SDK 10.2.7 and VS2012.
Everything is working fine on my my developer PC (Win10); tested also on PCs with Win8 and Win7 and all it's OK.
Then I try to deploy the application on a GETAC E100 (which on paper fullfills all the ArcGIS runtime SDK requirements).
What happens is that the application runs without any error (I mean nowhere, MS event viewer, directX logs, nothing !!!) but the map remain simply GRAY !!! I can move the mouse on the map and I see the coordinates changing; I can even zoom pinching with my fingers: everything works but the map is gray; I don't even see the base grids.
The application loads a simple TPK package I prepared using the ESRI Samples (ExportTileCache sample).
Here is the loading code:
XAML
<esri:MapView x:Name="myMapView" WrapAround="True" Grid.Column="1" BorderBrush="#FF7F7F7F" Margin="0,0,5,5" Style="{StaticResource NoLogoStyle}">
<esri:MapView.LocationDisplay>
<esri:LocationDisplay
AutoPanMode="Off"
DefaultSymbol="{StaticResource NotMovingMarkerSym}" CourseSymbol="{StaticResource MovingMarkerSym}"
IsEnabled="False" IsPingAnimationEnabled="False">
</esri:LocationDisplay>
</esri:MapView.LocationDisplay>
<esri:Map>
<!--<esri:MessageLayer ID="MyMessageLayer"/>-->
</esri:Map>
</esri:MapView>VB.NET behind code
Public Sub New()
' This call is required by the designer.
InitializeComponent()
' Force the spatial reference
myMapView.Map.SpatialReference = SpatialReference.Create(3857)
End Sub
Private Async Sub MainWindow_Loaded(sender As Object, e As RoutedEventArgs) Handles Me.Loaded
' Load the mission map data
Await LoadMissionMapData()
End Sub
Private Async Function LoadMissionMapData() As Task
Try
Dim misDataFile As String = System.AppDomain.CurrentDomain.BaseDirectory + My.Settings.MissionDataFolder + "\" + My.Settings.MissonDataFile
Dim ltLayer = New ArcGISLocalTiledLayer(misDataFile)
If ltLayer IsNot Nothing Then
AddHandler myMapView.LayerLoaded, AddressOf MissionDataLoaded
myMapView.Map.Layers.Add(ltLayer)
End If
Catch ex As Exception
MessageBox.Show("Error: Could not read file from disk. Original error: " + ex.Message)
End Try
End Function
Private Async Sub MissionDataLoaded(sender As Object, e As LayerLoadedEventArgs)
If e.LoadError IsNot Nothing Then
Utils.WriteException(e.LoadError)
End If
If e.Layer IsNot Nothing AndAlso e.Layer.Status = LayerStatus.Initialized AndAlso e.Layer.DisplayName = "Mission Data" Then
myMapView.MaximumExtent = e.Layer.FullExtent
If myMapView.Map.SpatialReference Is Nothing Then
Utils.WriteLog("WKID undefined")
End If
End If
End Sub
Please, any help ?
