There are a lot of threads that talk about returning the coded domain values descriptions while using a queryTask but from the few examples I have seen using the 4.x API, I can't get anything to work. My code is below if anyone could help me. I haven't really found any examples along the same lines as to what I am trying to do.
<SPAN class="comment token">//build query task</SPAN>
<SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://services.arcgis.com/uHAHKfH1Z5ye1Oe0/arcgis/rest/services/misin_treatments_aquatic/FeatureServer/0"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//build query filter</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//added for testing</SPAN>
query<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//pass the url parameters.</SPAN>
<SPAN class="keyword token">var</SPAN> urlObject <SPAN class="operator token">=</SPAN> urlUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">urlToObject</SPAN><SPAN class="punctuation token">(</SPAN>window<SPAN class="punctuation token">.</SPAN>location<SPAN class="punctuation token">.</SPAN>href<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>urlObject<SPAN class="punctuation token">.</SPAN>query<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>urlObject<SPAN class="punctuation token">.</SPAN>query<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN> OID <SPAN class="operator token">=</SPAN> urlObject<SPAN class="punctuation token">.</SPAN>query<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">//set query based on the parameters</SPAN>
<SPAN class="keyword token">var</SPAN> treatmentid <SPAN class="operator token">=</SPAN> <SPAN class="string token">"OBJECTID = '"</SPAN> <SPAN class="operator token">+</SPAN> OID <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">;</SPAN>
query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> treatmentid<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// execute query, place graphic on map and zoom to graphic</SPAN>
queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">close</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> resultFeatures <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
resultFeatures<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>gra<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
gra<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> sym<SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>gra<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
gra<SPAN class="punctuation token">.</SPAN>popupTemplate <SPAN class="operator token">=</SPAN> popupTemplate<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Provide graphic to a new instance of a Feature widget</SPAN>
<SPAN class="keyword token">const</SPAN> feature <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Feature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"attributes"</SPAN><SPAN class="punctuation token">,</SPAN>
graphic<SPAN class="punctuation token">:</SPAN> gra<SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">.</SPAN>spatialReference
<SPAN class="keyword token">var</SPAN> AOI <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN>AOI<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
