Hello all,
I have just found that I cannot see the GlobalID attribute in an AGSGDBFeature object from a local geodatabase used by an iOS SDK app that I'm working on. We have two feature classes (A and
. Features in B have a GUID attribute that stores the GlobalID attribute of a related feature in A.
In the iOS runtime SDK, an AGSGDBFeature from featureclass B will allow me to access the GUID attribute that refers to the GlobalID of a feature in A (e.g., NSLog(@A GUID from featureclass B: %@", [feature attributeAsStringForKey:@A_GUID]); ).
However, an AGSGDBFeature from featureclass A does not give me access to the GlobalID attribute anywhere. For example, I have logged-out the complete attributes from a feature in featureclass A (e.g., NSLog(@All attributes: %@",[[featureA allAttributes] description]); ), and there is a definite absence of the GlobalID attribute.
Is here something I'm doing wrong? Or is there a deliberate reason that we should not have (read-only) access to the global ID attribute? Perhaps there is there some other way I can get at it? I can see the globalid in the SQLite geodatabase file...
The main reason I'd want access to the globalid attribute in featureclass A is so that I can use it to populate the corresponding GUID field in featureclass B for related features.
