I've been asked to display all maps as British National Grid. I have managed get this working using the OS Open Raster REST service and using some example code found here: https://codepen.io/digz6666/pen/wPwPbW
We subscribe to ViaEuropa, we have access to more detailed master maps. There documentations is here: WMTS | viaEuropa Documentation
I'm trying to use this service on my map, but i'm not sure how. When i try updating the code above from codepen with the following (substituting my details in the curly brackets) url https://tile.viaeuropa.uk.com/{id}/{map}/wmts/1.0.0/WMTSCapabilities.xml the map doesn't load. Are they supplying basemaps or layers?
This is the xml response i see when i view WMTSCapabilities.xml in the browser. How do i use this data with arcgis js api 3.29?
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Capabilities</SPAN> <SPAN class="attr-name token">xmlns</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.opengis.net/wmts/1.0<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>ows</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.opengis.net/ows/1.1<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xlink</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/1999/xlink<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xsi</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/2001/XMLSchema-instance<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>gml</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.opengis.net/gml<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>schemaLocation</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.opengis.net/wmts/1.0 http://schemas.opengis.net/wmts/1.0/wmtsGetCapabilities_response.xsd<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">version</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>1.0.0<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- Service Identification --></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceIdentification</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>viaEuropa WMTS (m0105)<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Abstract</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xml:</SPAN>lang</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>en<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
viaEuropa WMTS from Europa Technologies. https://www.europa.uk.com
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Abstract</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceType</SPAN><SPAN class="punctuation token">></SPAN></SPAN>OGC WMTS<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceType</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceTypeVersion</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.0.0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceTypeVersion</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceIdentification</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceProvider</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ProviderName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Europa Technologies Ltd.<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>ProviderName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>ProviderSite</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xlink:</SPAN>href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://www.europa.uk.com<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>ServiceProvider</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- Operations Metadata --></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>OperationsMetadata</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Operation</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>GetCapabilities<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>DCP</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>HTTP</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Get</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xlink:</SPAN>href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://tile.publicsectormapping.gov.scot/*REDACTED*/m0105/wmts/1.0.0/WMTSCapabilities.xml<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Constraint</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>GetEncoding<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>AllowedValues</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>RESTful<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>AllowedValues</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Constraint</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Get</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Get</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xlink:</SPAN>href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://tile.publicsectormapping.gov.scot/*REDACTED*/m0105/wmts?<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>KVP<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Value</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>HTTP</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>DCP</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Operation</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Operation</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>GetTile<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Get</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xlink:</SPAN>href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://tile.publicsectormapping.gov.scot/*REDACTED*/m0105/<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>OperationsMetadata</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="comment token"><!-- Contents --></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Contents</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Layer</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
m0105 - Ordnance Survey (GB) premium raster stack to MM Topo (BNG)
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>viaEuropa_m0105<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>WGS84BoundingBox</SPAN> <SPAN class="attr-name token">crs</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>urn:ogc:def:crs:OGC:2:84<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>LowerCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-10.0 49.6<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>LowerCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>UpperCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4.55 62.7<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>UpperCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>WGS84BoundingBox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>BoundingBox</SPAN> <SPAN class="attr-name token">crs</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>urn:ogc:def:crs:EPSG::27700<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>LowerCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0 0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>LowerCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>UpperCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>700000 1300000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>UpperCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>BoundingBox</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Style</SPAN> <SPAN class="attr-name token">isDefault</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>true<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<<SPAN class="property token">ows</SPAN><SPAN class="punctuation token">:</SPAN>Identifier>default</<SPAN class="property token">ows</SPAN><SPAN class="punctuation token">:</SPAN>Identifier>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Format</SPAN><SPAN class="punctuation token">></SPAN></SPAN>image/png<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Format</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileMatrixSetLink</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileMatrixSet</SPAN><SPAN class="punctuation token">></SPAN></SPAN>BNGCompatible<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileMatrixSet</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileMatrixSetLink</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ResourceURL</SPAN> <SPAN class="attr-name token">format</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>image/png<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">resourceType</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>tile<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">template</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://tile.publicsectormapping.gov.scot/*REDACTED*/m0105/wmts/tile_inv/{TileMatrix}/{TileCol}/{TileRow}.png<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Layer</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>BritishNationalGridCompatible<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Abstract</SPAN><SPAN class="punctuation token">></SPAN></SPAN>British National Grid tile matrix set<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Abstract</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>BNGCompatible<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>SupportedCRS</SPAN><SPAN class="punctuation token">></SPAN></SPAN>urn:ogc:def:crs:EPSG::27700<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>SupportedCRS</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileMatrix</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TopLeftCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0 1433600<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TopLeftCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>256<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>256<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileMatrix</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>5000000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2500000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>3<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1000000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>20<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>500000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>20<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>40<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>5<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>250000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>40<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>80<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>6<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>100<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>200<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>7<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>75000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TopLeftCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0 1430016<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TopLeftCorner</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>133<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>266<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>50000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>200<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>400<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>9<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>25000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>400<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>800<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>11<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>5000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>12<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2500<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>13<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1250<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>16000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>14<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>625<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>16000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>32000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>15<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">ows:</SPAN>Identifier</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>312.5<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ScaleDenominator</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>32000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixWidth</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>64000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MatrixHeight</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Contents</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ServiceMetadataURL</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xlink:</SPAN>href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://tile.publicsectormapping.gov.scot/*REDACTED*/m0105/wmts/1.0.0/WMTSCapabilities.xml<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Capabilities</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
