I am trying to get all features on multiple feature layers inside of a polygon.I was doing polygon.contains(), it works great for point type feature layer, but not for polyline type or polygon type feature layer.Then I was directed to implement this in different way, which is doing query on feature layer, by setting query.geomotry = polygon.geometry.It works fine for single layer, but when it comes to multiple layers, I have trouble to get correct result.What I am getting, is always the selected features for last layer. Does it clear the selectFeatures result from previous layer every time run for next layer? I did try SELECTION_ADD mode, which is not working either.Here is the codevar query = new esri.tasks.Query(); query.geometry = area.geometry; var counter = 0; var listOfSelectedFeatures; for (var j = 0; j < map.graphicsLayerIds.length; j++) { var currentLayer = map.getLayer(map.graphicsLayerIds); currentLayer.selectFeatures(query, currentLayer.SELECTION_NEW, function () { counter++; if (counter == (map.graphicsLayerIds.length - 1)) { for (var k = 0; k < map.graphicsLayerIds.length; k++) { var layer = map.getLayer(map.graphicsLayerIds); if (listOfSelectedFeatures == undefined) { listOfSelectedFeatures = layer.getSelectedFeatures(); } else { listOfSelectedFeatures.concat(layer.getSelectedFeatures()); } } } }); } Thanks,Tony
