Hi,I'm a beginner in Python and trying to build a script to perform and extraction from a Oracle database to a file geodatabase with a SQL query. I've been able to etablish the connection to Oracle, select the data with the query, create a new table but I have not been able to successfully output the data to the file Geodatabase.Here the error from the geoprocessing result.
Voici mon code : #! /usr/bin/env python
#encoding:UTF-8
import cx_Oracle
#import csv
import arcpy
from arcpy import env
# Define workspace
env.workspace = "C:\Temp\Extraction_Toad\Scratch_Toad.gdb"
# Add connections setting
dsn = cx_Oracle.makedsn("xyz","xyz","X")
orcl = cx_Oracle.connect('xyz','xyz',dsn)
cursor = orcl.cursor()
# Get the variables
arg1 = arcpy.GetParameterAsText(0)
out_path = arcpy.GetParameterAsText(1)
out_name = arcpy.GetParameterAsText(2)
template = "C:\Temp\Extraction_Toad\Template_vue.dbf"
out_workspace = "C:\Temp\Extraction_Toad\Scratch_Toad.gdb"
# Process the query
sql = arg1
cursor.execute(sql)
rows = cursor.fetchall()
cursor.close()
orcl.close()
# Create a new table
arcpy.CreateTable_management(out_path,out_name,template)
# Loading data from the cursor to file g
for row in rows:
arcpy.CopyRows_management(row,out_workspace)
Thanks for you help
