I would like to add a simple if statement to an existing expression, but am having difficulties getting it to execute. My previous expression in vb script concatenates a number of fields to make one long string in a new field. I would like to add multiple if else statements to be a part of this expression.
'Trim([NUMBERCYLA]) & ",SB,"& Trim([RESOLUTION_CODE]) & ",,,SC Truck,"& Trim([last_edited_user])& ",Driver,"& Month( [last_edited_date])&"/"& Day([last_edited_date])&"/"& Year ( [last_edited_date]) & ","'
I have a field SCCatDesc that contains the attributes MAT, MBE, MBI, MBW, SBE, and SBI.
If SCCatDesc = MAT then output = SB
If SCCatDesc = MBE then output = ME
If SCCatDesc = MBI then output = MB
If SCCatDesc = MBW then output = MW
If SCCatDesc = SBE then output = SB
If SCCatDesc = SBI then output = SBI
I have tried the following as start however it does not work.
- If [SCCatDesc] = "MAT" Then
- Output = "SB"
- ElseIf [SCCatDesc] = "MBE" Then
- Output = "ME"
- Else
- Output = "TEST"
- End If
import arcpy
#Define Local Parameters
whereclause = "PlannedDate = CONVERT(DATE, GETDATE())"
SDEFeatureClass = "C:\Users\Administrator\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog\Connection to localhost_SCData_sa.sde\SCData.DBO.SO_SC"
LocalFGDB = "C:\PeterText.gdb"
Outable = "WLATable"
PeterTable = "C:\PeterText.gdb\WLATABLE"
expression = 'Trim([NUMBERCYLA]) & ",SB,"& Trim([RESOLUTION_CODE]) & ",,,SC Truck,"& Trim([last_edited_user])& ",Driver,"& Month( [last_edited_date])&"/"& Day([last_edited_date])&"/"& Year ( [last_edited_date]) & ","'
#Selection Query
selection = """CYLA_DISTRICT = 'WLA' AND PlannedDate = CONVERT(DATE, GETDATE())"""
#Deletes old FC
if arcpy.Exists(PeterTable):
arcpy.Delete_management(PeterTable)
#Sends Feature Class to Table with Where Clause
arcpy.TableToTable_conversion(SDEFeatureClass, LocalFGDB, Outable, selection)
#Calculates Field with expression for Peter Text File
arcpy.CalculateField_management(PeterTable, "PtrText", expression)
#Search Cursor to extract Peter Text Field
myOutputFile = open("C:\PeterScripts\WLA\Peter.txt", 'w')
rows = arcpy.da.SearchCursor("C:\PeterText.gdb\WLATable", ["PtrText"])
for row in rows:
myOutputFile.write(str(row[0]) + '\n')
del row, rows
myOutputFile.close()
