Hi,My app has a memory leak that I haven't been able to resolve. Instruments show the leak on the didFindLocationsForAddress method of the AGSLocatorDelegate. Can someone help me figuring out what is wrong in my code?According to Instruments, the problem is when I'm using (on the code bellow)::[addressCandidate.attributes mutableCopy]- (void)locator:(AGSLocator *)locator operation:(NSOperation *)op didFindLocationsForAddress:(NSArray *)candidates
//check and see if we didn't get any results
if (candidates == nil || [candidates count] == 0)
//show alert if we didn't get results
UIAlertView *alert = [[UIAlertView alloc] initWithTitle:@No Results
message:@No Results Found By Locator
delegate:nil
cancelButtonTitle:@OK
otherButtonTitles:nil];
[alert show];
[alert release];
else
AGSAddressCandidate *addressCandidate = (AGSAddressCandidate *)[candidates objectAtIndex:0];
//get the location from the candidate
AGSPoint *pt = addressCandidate.location;
//create a marker symbol to use in our graphic
AGSPictureMarkerSymbol *marker = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImageNamed:@BluePushpin.png];
marker.hotspot = CGPointMake(-9, -11);
int levelToZoomTo = 4;
AGSLOD* lod = [tiledMapServiceLayer.mapServiceInfo.tileInfo.lods objectAtIndex:levelToZoomTo];
float zoomFactor = lod.resolution/self.mapView.resolution;
AGSMutableEnvelope *newEnv =
[AGSMutableEnvelope envelopeWithXmin:self.mapView.envelope.xmin
ymin:self.mapView.envelope.ymin
xmax:self.mapView.envelope.xmax
ymax:self.mapView.envelope.ymax
spatialReference:self.mapView.spatialReference];
[newEnv expandByFactor:zoomFactor];
[self.mapView zoomToEnvelope:newEnv animated:YES];
//create the graphic
AGSGraphic *graphic = [[AGSGraphic alloc] initWithGeometry: pt
symbol:marker
attributes:[addressCandidate.attributes mutableCopy]
infoTemplateDelegate:nil];
//add the graphic to the graphics layer
[self.graphicsLayer addGraphic:graphic];
//release the graphic
[graphic release];
NSLog(@point %@", pt);
//we have one result, center at that point
[self.mapView centerAtPoint:pt animated:NO];
[self.graphicsLayer dataChanged];
