All,I am porting an old VB6 project to a 10.2.1 VB .Net ESRI AddIn and hit the "wall".On the old VB6 toolbar I had a TextBox which was an editbox on a form with a class implementing IToolControl and ICommand. I am attempting to recreate this as part of my AddIn toolbar.First of all unless I have missed something there is no textbox addin?Assuming this is the case I have created a usercontrol with nothing more than a label and an editbox on it. I have then created a class that implements IToolControl and ICommand.In this Class I have a private object which is an instance of the userControlPrivate m_UC As HER_AddIn.ucTextBox = New HER_AddIn.ucTextBox
In the property hWnd I return Public ReadOnly Property hWnd As Integer Implements ESRI.ArcGIS.SystemUI.IToolControl.hWnd
Get
Return m_UC.Handle.ToInt32
End Get
End Property
So far so good...Now I want to add this usercontrol to the toolbar, how do I actually do that? What am I supposed to write in the Config.esriaddinx file? Typically you declare a <command> and then reference that command in the <toolbar>The only options when creating a command are <Button>,<Combobox>,<MultiItem>,<Tool> etcHow on Earth do I add a usercontrol to the AddIn toolbar?
