I would like to calculate the elevation of each point during an edit session. I am capturing the location of the edited point using the before-apply-edits event. However, I could not get the ImageServiceIdentifyTask to execute (Also tried IdentifyTask in case I was missing something).
I can manually query my imageservice at demImageURL successfully from the ArcGIS REST Services Directory on my server.
I am adding the code. What am I missing? Thanks.
systemEditor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyDemTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ImageServiceIdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>demImageURL<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>demImageURL<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>tolerance <SPAN class="operator token">=</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>width <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>width<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>height<SPAN class="punctuation token">;</SPAN>
systemEditor<SPAN class="punctuation token">.</SPAN>templatePicker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"selection-change"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> selected <SPAN class="operator token">=</SPAN> systemEditor<SPAN class="punctuation token">.</SPAN>templatePicker<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getSelected</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>selected<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> featureLayer <SPAN class="operator token">=</SPAN> selected<SPAN class="punctuation token">.</SPAN>featureLayer<SPAN class="punctuation token">;</SPAN>
On<SPAN class="punctuation token">.</SPAN><SPAN class="token function">once</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"before-apply-edits"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>adds <SPAN class="operator token">&&</SPAN> evt<SPAN class="punctuation token">.</SPAN>adds<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> imageParams <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ImageServiceIdentifyParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> point <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>adds<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> evt<SPAN class="punctuation token">.</SPAN>adds<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">,</SPAN> evt<SPAN class="punctuation token">.</SPAN>adds<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
imageParams<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> point<SPAN class="punctuation token">;</SPAN>
imageParams<SPAN class="punctuation token">.</SPAN>mapExtent <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> point<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>mapExtent <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> deferred <SPAN class="operator token">=</SPAN> identifyTask
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>identifyParams<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addCallback</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// I see nothing here</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> deferred2 <SPAN class="operator token">=</SPAN> identifyDemTask
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>imageParams<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>adds<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hasOwnProperty</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'elevation'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// to go inside the deferred execution</SPAN>
systemEditor<SPAN class="punctuation token">.</SPAN>attributeInspector<SPAN class="punctuation token">.</SPAN><SPAN class="token function">refresh</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
