UniqueValueRenderer and ArcGISDynamicMapServiceLayer and SimpleMarkerSymbol
no longer seem to work properly together.
I'm using ARCGIS Server 10.2 and ARCGIS Javasript API 3.18.
I use the unique value render with SImpleFillSymbols and it works perfectly and at one point our application did have UniqueRendering working with Symbols.
Not sure if this was broken at some point within 3.1x or if its simply not possibly any more.
When I DO choose to use UniqueValueRender with SimpleMarkerSymbol the features render as gray filled symbols.
Picture attached.
Any insights would be enormously helpful.
**I know that the general code I have developed does in fact work and render using SimpleFillSymbols on the same field that won't generate a render with SimpleMarkerSymbols**
Thanks.
