Does anyone know what the '-1' refers to in the 'Max Token Expiration Minutes' on Portal? I went to change this value following these instructions and expected it to be 20,160 (2 weeks) - Specify the default token expiration time—Portal for ArcGIS (10.4) | ArcGIS for Server
Does '-1' mean there is no expiration or does it mean the default of two weeks?
Matt
Can someone please address this?
Hi Michael and Matt,
In Portal for ArcGIS, the '-1' value for 'Max Token Expiration Minutes' represents a default of two weeks (or 20,160 minutes) validity for access tokens.
In addition to being the default value, 2 weeks also represents the max expiration value acceptable for access tokens - attempting to update this value to anything greater than 20,160 will not be accepted by the software. This is not explicitly stated in the Portal documentation - we will work to improve the info on the referenced doc page in future releases: Specify the default token expiration time—Portal for ArcGIS (10.6) | ArcGIS Enterprise.
Let me know if this helps.
Jeff
Are there any options around this? To get a token generated for longer than 2 weeks?
Hi @Anonymous User ,
Apologies for the delayed response.
Unfortunately, there is no workaround for this. Two weeks is the max limit token expiration for a regular or oauth access token. Thanks,
Los miembros registrados pueden publicar, seguir actualizaciones y más. ¿Nuevo aquí? Regístrate gratis.
