I am trying to change basemaps without the BaseMap widget.I can accomplish this BUT I have two buttons and I only want ONE..I am trying to invision how to do this with one button....1. I should be able to use a toggler of some sort2. if not I can use an If Then statement or a Case as seen below BUT would need to fidn out how to determine the name of the current basemap that is being displayed..
map = new esri.Map("map", {
basemap: "topo",
If I am looking at the code above....1. How do I test for the basemap? Return to a variable and then I can use in the Case below.I tried this and got 'undefined'
var layer = map.getLayer('basemap');
var layerUrl;
switch(basemap){
case 'topo':
layerUrl = 'https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer';
break;
case 'imagery':
layerUrl = 'https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer';
break;
var basemap = new esri.layers.ArcGISTiledMapServiceLayer(layerUrl,{id:'basemap'});
map.addLayer(basemap,0);
alert(layer);
WORKING CODE BUT TWO BUTTONS
<div dojotype='dijit.layout.ContentPane' region='top' style='height:20px;'>
<input type='button' value='Topo' onclick='switchMap("topo");'/>
<input type='button' value ='Imagery' onclick='switchMap("imagery");'/>
</div>
map = new esri.Map("map",{
extent:initExtent
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer",{id:'basemap'});
map.addLayer(basemap);
function switchMap(basemap){
//remove the existing basemap layer
map.removeLayer(layer);
var layerUrl;
switch(basemap){
case 'topo':
break;
case 'imagery':
break;
