Boilerplate widgets (Simple, Editor) are called twice. According to various write ups this is due to React.StrictMode and is expected.
It's an intentional feature of the StrictMode. This only happens in development, and helps find accidental side effects put into the render phase.
I'd expect this shouldn't happen in a published app, but it does. Here is a raw copy of the Simple widget. "here" hits the console twice in a published app.
<SPAN class="token function">render</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>
<SPAN class="operator token"><</SPAN>div className<SPAN class="operator token">=</SPAN><SPAN class="string token">"widget-demo jimu-widget m-2"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>p<SPAN class="operator token">></SPAN>Simple Widget<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>p<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>p<SPAN class="operator token">></SPAN>exampleConfigProperty<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>props<SPAN class="punctuation token">.</SPAN>config<SPAN class="punctuation token">.</SPAN>exampleConfigProperty<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>p<SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">{</SPAN>console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"here"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Is this a bug? If not, how might I avoid my widget rendering twice?
