I have an asynchronous geoprocessing service which returns a raster result via a map service. The GP service is fully functional -- I can run it via the REST endpoint or inside ArcMap with no problems. I developed a custom widget which sits inside the Flex Viewer (3.6) to allow user to pass the input parameters to the GP service and handle the result. This setup is working for me most of the time. I've run the GP service several times in a row with no problems -- the result is returned, displayed properly & all is well. Other times, the result is not returned and I get a this error: "faultCode:400 faultString:'Invalid or missing input parameters.' faultDetail:''".To be clear, this is a geoprocessing result map service. I can see that the GP service completed successfully -- the event.jobInfo.jobStatus == JobInfo.STATUS_SUCCEEDED. But the map service that is supposed to be created isn't always created.As a workaround, I've gone through various iterations of trying to reload the map service and finally made an error handler that fires if the map service does not load. It resubmits the GP Service requestObject and runs the whole thing again. Sometimes it will work on the 2nd go round, other times it takes a a couple tries. I've tried inserting a 1 second pause (after STATUS_SUCCEEDED) before trying to load the map, but to no avail. (This should also not be necessary since "getResultMapServiceLayer(jobId:String):ArcGISDynamicMapServiceLayer Creates and configures an ArcGISDynamicMapServiceLayer instance ready to be added to a Map."I've pasted in the relevant code below. Any thoughts or guidance would be much appreciated.-Erik //fires when geoprocessor finishes. retrives result data protected function gp_jobCompleteHandler(event:GeoprocessorEvent):void { if (event.jobInfo.jobStatus == JobInfo.STATUS_SUCCEEDED) { statusArea.appendText("Retrieving results from server..." + "\n"); scenarioIterator += 1 resMapServ = gp.getResultMapServiceLayer(gp.submitJobLastResult.jobId) resMapServ.name = "Scenario" + String(scenarioIterator) if (resMapServ.loaded) { map.addLayer(resMapServ) } else { resMapServ.addEventListener(LayerEvent.LOAD, resMapServ_loadHandler, false, 0, true); resMapServ.addEventListener(LayerEvent.LOAD_ERROR, resMapServ_loadErrorHandler, false, 0, true); function resMapServ_loadHandler(event:LayerEvent):void { resMapServ.removeEventListener(LayerEvent.LOAD, resMapServ_loadHandler); resMapServ.removeEventListener(LayerEvent.LOAD_ERROR, resMapServ_loadErrorHandler); map.addLayer(resMapServ) } function resMapServ_loadErrorHandler(event:LayerEvent):void { Alert.show("There was a problem loading the result. \n The analysis is being re-run. \n Sorry for the inconvenience.\n" +event.fault.message) gp.submitJob(requestObject); } } } else { var messages1:Array = event.jobInfo.messages; var count1:int = messages1.length; var index1:int = count1-4; var message1:String = messages1[index1].description; Alert.show("Geoprocessing Error:\n" + message1); } }
