If I have an array of values, can't use these as input to a where clause? I am allowing the user to select multiple checkboxes, pushing the values into an array as they check. Then I want to be able to create a where clause for either a queryTask or a featureLayer.
I have an example of a where clause that looks like I can use IN, but I'm having a hard time getting the values from the array to be properly formatted. I am using a cbTree, which is a checkbox tree. The values from the checkboxes are getting populated into the array, I'm just not sure what to do with them next.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>CheckBox Tree Example</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.11/dijit/themes/claro/claro.css"/>
<link rel="stylesheet" href="cbtree/themes/claro/claro.css"/>
<script type="text/javascript">
var dojoConfig = {
parseOnLoad: false,
async:true,
packages: [{
"name": "cbtree",
"location": location.pathname.replace(/\/[^/]+$/, "")+'/cbtree'
</script>
<script type="text/javascript" src="https://js.arcgis.com/3.11/"></script>
var popup, map, geocoder, layer, template, symbol;
var searchList = [];
var pathName = "https://myserver.mo.gov";
require([
"dojo/parser","dojo/dom-style", "dojo/dom-construct","esri/dijit/Popup","dojo/store/Memory",
"dojo/store/Observable","cbtree/Tree", "cbtree/store/ObjectStore", "cbtree/model/ForestStoreModel",
"cbtree/extensions/TreeStyling",
"esri/map", "esri/layers/GraphicsLayer",
"esri/symbols/PictureMarkerSymbol","esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol",
"esri/InfoTemplate","esri/tasks/query","esri/tasks/QueryTask",
"dojo/_base/Color", "dojo/dom","dojo/on","dijit/registry", "dojo/_base/array",
"dijit/layout/BorderContainer","dijit/layout/TabContainer","dijit/layout/ContentPane","dijit/form/Button",
"dijit/TitlePane", "dojo/domReady!" ], function (
parser,domStyle,domConstruct, Popup, Memory, Observable,Tree, ObjectStore, StoreModel,
TreeStyling, Map,GraphicsLayer,PictureMarkerSymbol, SimpleMarkerSymbol,
SimpleLineSymbol,InfoTemplate,Query,QueryTask, Color, dom,on, registry, arrayUtils) {
parser.parse();
var qTask = new QueryTask(pathName+"/arcgis/rest/services/DHSS/medicalFacility/MapServer/0");
var searchQuery = new Query();
searchQuery.returnGeometry = false;
searchQuery.outFields = ["Facility", "Address", "City","Hosp_Type", "OBJECTID"];//fields you want in your grid
var data = [
// { id: "Provider", name:"Provider Types", type:"header"},
{ id: "CA", name:"Critical Access", type:"parent"},
{ id: "GA", name:"General Acute Care", type:"parent"},
{ id: "LT", name:"Long Term Care", type:"parent" },
{ id: "PSY", name:"Psychiatric", type:"parent" },
{ id: "REH", name:"Rehabilitation", type:"parent" },
{ id: "VA", name:"Veterans", type:"parent"},
{ id: "OT", name:"Other", type:"parent"}
var store = new Memory( { data: data });
// var store = Observable( new Memory( { data: data }));
var model = new StoreModel( { store: store,
rootLabel: "Specialty Type",
showRoot:false,
query: {type: 'parent'},
tree = new Tree( {
model: model,
branchReadOnly: false,
branchcheckBox:true,
branchIcons: false,
nodeIcons: false,
leafIcons:false,
rootNode:false
}, "CheckboxTree" );
tree.startup();
// Establish listener and start the tree.
function checkBoxClicked( item, nodeWidget, evt ) {
var newState = nodeWidget.get("checked" );
var label = this.model.getLabel(item);
if( newState ) {
searchList.push(label);
} else {
//---------------this is the section I have questions about
function executeQuery(){
searchList.sort();
var sortedList = sortAndRemoveDuplicates(searchList);
var sortedString = sortedList.split(', ').join("','");
var whereClause = "HOSP_TYPE IN ('" + sortedString + "')";//clause isn't formated properly here
console.log("whereClause = " + whereClause);
query.where = whereClause;
queryTask.execute(query,queryHandler);
function queryHandler(results){
console.log("in queryHandler");
function sortAndRemoveDuplicates(arr) {
arr.sort( function(a, b) { return a - b; } );
var copy = arr.slice(0);
arr.length = 0;
for (var i = 0, len = copy.length; i < len; ++i) {
if (i == 0 || copy != copy[i - 1]) {
arr.push(copy);
return arr;
//event listeners
tree.on( "checkBoxClick", checkBoxClicked );
registry.byId('btnSearch').on('click', executeQuery);
</script>
</head>
<body class="claro">
<h1 class="DemoTitle">The CheckBox Tree with Multi State CheckBoxes</h1>
<p>
A basic CheckBox Tree using a dojo/store Memory store (non-observable).
</p>
<div id="CheckboxTree">
</div>
<button id="btnSearch" data-dojo-type="dijit/form/Button">Search</button>
</body>
</html>
