Hi guys
I am trying to select polygon features using sketchViewModel, using this sample code.
I removed CSV layer with FeatureLayer.
But now, when i select features, in table i see only OBJECTID, it applies column headers for other fields, but without data.
see Pic. for error and Code below.
Thank you in advance.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN>
content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Highlight features by geometry <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.14</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link
rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN>
href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.14/esri/themes/light/main.css"</SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.14/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
#info<SPAN class="punctuation token">,</SPAN>
#gridDisplay <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN>
bottom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">35</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN>
border<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> grey<SPAN class="punctuation token">;</SPAN>
font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 14px<SPAN class="punctuation token">;</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">80</SPAN><SPAN class="punctuation token">;</SPAN>
#info <SPAN class="punctuation token">{</SPAN>
z<SPAN class="operator token">-</SPAN>index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">90</SPAN><SPAN class="punctuation token">;</SPAN>
font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 16px<SPAN class="punctuation token">;</SPAN>
padding<SPAN class="operator token">-</SPAN>left<SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
#info <SPAN class="operator token">*</SPAN> <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="operator token">-</SPAN>right<SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>info <SPAN class="punctuation token">{</SPAN>
line<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> 20px<SPAN class="punctuation token">;</SPAN>
padding<SPAN class="operator token">-</SPAN>left<SPAN class="punctuation token">:</SPAN> 5px <SPAN class="operator token">!</SPAN>important<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>header<SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>header<SPAN class="operator token">-</SPAN>row <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> #eee<SPAN class="punctuation token">;</SPAN>
color<SPAN class="punctuation token">:</SPAN> #57585a<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>row<SPAN class="operator token">-</SPAN>even <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> #f7f8f8<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>row<SPAN class="operator token">-</SPAN>odd <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> #efefef<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>selected <SPAN class="punctuation token">{</SPAN>
background<SPAN class="punctuation token">:</SPAN> #b4daf5<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>dgrid<SPAN class="operator token">-</SPAN>row <SPAN class="punctuation token">{</SPAN>
border<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Sketch/SketchViewModel"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Legend"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Expand"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/FeatureForm"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dgrid/OnDemandGrid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dgrid/extensions/ColumnHider"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/store/Memory"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dstore/legacy/StoreAdapter"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dgrid/Selection"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
WebMap<SPAN class="punctuation token">,</SPAN>
MapView<SPAN class="punctuation token">,</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN>
GraphicsLayer<SPAN class="punctuation token">,</SPAN>
SketchViewModel<SPAN class="punctuation token">,</SPAN>
Graphic<SPAN class="punctuation token">,</SPAN>
Legend<SPAN class="punctuation token">,</SPAN>
Expand<SPAN class="punctuation token">,</SPAN>
FeatureForm<SPAN class="punctuation token">,</SPAN>
OnDemandGrid<SPAN class="punctuation token">,</SPAN>
ColumnHider<SPAN class="punctuation token">,</SPAN>
Memory<SPAN class="punctuation token">,</SPAN>
StoreAdapter<SPAN class="punctuation token">,</SPAN>
Selection
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> map<SPAN class="punctuation token">,</SPAN>
view<SPAN class="punctuation token">,</SPAN>
flLayer<SPAN class="punctuation token">,</SPAN>
csvLayerView<SPAN class="punctuation token">,</SPAN>
polygonGraphicsLayer<SPAN class="punctuation token">,</SPAN>
sketchViewModel<SPAN class="punctuation token">,</SPAN>
highlight<SPAN class="punctuation token">,</SPAN>
grid<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> gridDiv <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"grid"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> infoDiv <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"info"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create new map, view and csvlayer</SPAN>
<SPAN class="token function">setupTheView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a new sketchviewmodel, setup it properties</SPAN>
<SPAN class="comment token">// set up the click event for the select by polygon button</SPAN>
<SPAN class="token function">setUpSketchViewModel</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"create"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"complete"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// this polygon will be used to query features that intersect it</SPAN>
polygonGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> gridFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Req_Code"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"abonentebis_raodenoba"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dasaxeleba"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Semqmneli"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"statusi"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a new datastore for the on demandgrid</SPAN>
<SPAN class="comment token">// will be used to display attributes of selected features</SPAN>
<SPAN class="keyword token">const</SPAN> dataStore <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">StoreAdapter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
objectStore<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Memory</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
idProperty<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN>
<SPAN class="comment token">// create a grid with given columns once the csvlayer is loaded</SPAN>
csvLayer
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// create a grid with columns specified in gridFields variable</SPAN>
<SPAN class="token function">createGrid</SPAN><SPAN class="punctuation token">(</SPAN>csvLayer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// get a reference the csvlayerview when it is ready. It will used to do</SPAN>
<SPAN class="comment token">// client side queries when user draws polygon to select features</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenLayerView</SPAN><SPAN class="punctuation token">(</SPAN>csvLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layerView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
csvLayerView <SPAN class="operator token">=</SPAN> layerView<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN>errorCallback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/****************************************************
* Selects features from the csv layer that intersect
* a polygon that user drew using sketch view model
****************************************************/</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">selectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>geometry<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>csvLayerView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// create a query and set its geometry parameter to the</SPAN>
<SPAN class="comment token">// polygon that was drawn on the view</SPAN>
<SPAN class="keyword token">const</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> geometry<SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// query graphics from the csv layer view. Geometry set for the query</SPAN>
<SPAN class="comment token">// can be polygon for point features and only intersecting geometries are returned</SPAN>
csvLayerView
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> graphics <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// if the grid div is displayed while query results does not</SPAN>
<SPAN class="comment token">// return graphics then hide the grid div and show the instructions div</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>graphics<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// zoom to the extent of the polygon with factor 2</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">goTo</SPAN><SPAN class="punctuation token">(</SPAN>geometry<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
gridDiv<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>zIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">90</SPAN><SPAN class="punctuation token">;</SPAN>
infoDiv<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>zIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">80</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"featureCount"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN>
<SPAN class="string token">"<b>Showing attributes for "</SPAN> <SPAN class="operator token">+</SPAN>
graphics<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">" features </b>"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
gridDiv<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>zIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">80</SPAN><SPAN class="punctuation token">;</SPAN>
infoDiv<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>zIndex <SPAN class="operator token">=</SPAN> <SPAN class="number token">90</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// remove existing highlighted features</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>highlight<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
highlight<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// highlight query results</SPAN>
highlight <SPAN class="operator token">=</SPAN> csvLayerView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">highlight</SPAN><SPAN class="punctuation token">(</SPAN>graphics<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// get the attributes to display in the grid</SPAN>
<SPAN class="keyword token">const</SPAN> data <SPAN class="operator token">=</SPAN> graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">(</SPAN>
Object<SPAN class="punctuation token">.</SPAN><SPAN class="token function">keys</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>key<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// get fields that exist in the grid</SPAN>
<SPAN class="keyword token">return</SPAN> gridFields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>key<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// need to create key value pairs from the feature</SPAN>
<SPAN class="comment token">// attributes so that info can be displayed in the grid</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">reduce</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>obj<SPAN class="punctuation token">,</SPAN> key<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
obj<SPAN class="punctuation token">[</SPAN>key<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>key<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> obj<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// set the datastore for the grid using the</SPAN>
<SPAN class="comment token">// attributes we got for the query results</SPAN>
dataStore<SPAN class="punctuation token">.</SPAN>objectStore<SPAN class="punctuation token">.</SPAN>data <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">;</SPAN>
grid<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"collection"</SPAN><SPAN class="punctuation token">,</SPAN> dataStore<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* fires when user clicks a row in the grid
* get the corresponding graphic and select it
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">selectFeatureFromGrid</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// close view popup if it is open</SPAN>
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">close</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// get the ObjectID value from the clicked row</SPAN>
<SPAN class="keyword token">const</SPAN> row <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>rows<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> id <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">.</SPAN>OBJECTID<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// setup a query by specifying objectIds</SPAN>
objectIds<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="token function">parseInt</SPAN><SPAN class="punctuation token">(</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
returnGeometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="comment token">// query the csvLayerView using the query set above</SPAN>
csvLayerView
<SPAN class="comment token">// remove all graphics to make sure no selected graphics</SPAN>
<SPAN class="comment token">// create a new selected graphic</SPAN>
<SPAN class="keyword token">const</SPAN> selectedGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> graphics<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-fill"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleFillSymbol()</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"yellow"</SPAN><SPAN class="punctuation token">,</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"solid"</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"red"</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="comment token">// add the selected graphic to the view</SPAN>
<SPAN class="comment token">// this graphic corresponds to the row that was clicked</SPAN>
view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>selectedGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* Creates a new grid. Loops through poverty
* csvLayer's fields and creates grid columns
* Grid with selection and columnhider extensions
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createGrid</SPAN><SPAN class="punctuation token">(</SPAN>fields<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> columns <SPAN class="operator token">=</SPAN> fields
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filter</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>gridFields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!==</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> field<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">===</SPAN> <SPAN class="string token">"__OBJECTID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">{</SPAN>
field<SPAN class="punctuation token">:</SPAN> field<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> field<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN>
sortable<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
hidden<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
label<SPAN class="punctuation token">:</SPAN> field<SPAN class="punctuation token">.</SPAN>alias<SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// create a new onDemandGrid with its selection and columnhider</SPAN>
<SPAN class="comment token">// extensions. Set the columns of the grid to display attributes</SPAN>
<SPAN class="comment token">// the hurricanes cvslayer</SPAN>
grid <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="punctuation token">(</SPAN>OnDemandGrid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createSubclass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>Selection<SPAN class="punctuation token">,</SPAN> ColumnHider<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">(</SPAN>
columns<SPAN class="punctuation token">:</SPAN> columns
<SPAN class="comment token">// add a row-click listener on the grid. This will be used</SPAN>
<SPAN class="comment token">// to highlight the corresponding feature on the view</SPAN>
grid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"dgrid-select"</SPAN><SPAN class="punctuation token">,</SPAN> selectFeatureFromGrid<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/************************************************************************
* Sets up the sketchViewModel. When user clicks on the select by polygon
* button sketchViewModel.create() method is called with polygon param.
************************************************************************/</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setUpSketchViewModel</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// polygonGraphicsLayer will be used by the sketchviewmodel</SPAN>
<SPAN class="comment token">// show the polygon being drawn on the view</SPAN>
polygonGraphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>polygonGraphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// add the select by polygon button the view</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"select-by-polygon"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> selectButton <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"select-by-polygon"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// click event for the button</SPAN>
selectButton<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">clearUpSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// ready to draw a polygon</SPAN>
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"polygon"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a new sketch view model set its layer</SPAN>
sketchViewModel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SketchViewModel</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
layer<SPAN class="punctuation token">:</SPAN> polygonGraphicsLayer<SPAN class="punctuation token">,</SPAN>
pointSymbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">clearUpSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
grid<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clearSelection</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
* Sets up the view. WebMap with winkel III projection
* basemap and hurricanes CsvLayer is added to the view.
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setupTheView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> url <SPAN class="operator token">=</SPAN>
<SPAN class="string token">"http://1ocalhost:6080/arcgis/rest/services/test/Request_Area/FeatureServer/0"</SPAN><SPAN class="punctuation token">;</SPAN>
csvLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Hurricanes"</SPAN><SPAN class="punctuation token">,</SPAN>
url<SPAN class="punctuation token">:</SPAN> url<SPAN class="punctuation token">,</SPAN>
copyright<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"GWP"</SPAN><SPAN class="punctuation token">,</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// contains a basemap with a Winkel III projection</SPAN>
<SPAN class="comment token">// the CSVLayer coordinates will re-project client-side</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"7d127cef99a44327b79f5185602b8b6b"</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>csvLayer<SPAN class="punctuation token">]</SPAN>
view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
highlightOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"#2B65EC"</SPAN><SPAN class="punctuation token">,</SPAN>
fillOpacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.4</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
bottom<SPAN class="punctuation token">:</SPAN> infoDiv<SPAN class="punctuation token">.</SPAN>clientHeight <SPAN class="comment token">// Same value as the #infoDiv height in CSS</SPAN>
<SPAN class="keyword token">const</SPAN> legendExpand <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Legend</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"card"</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>legendExpand<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>newValue<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>newValue<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">errorCallback</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"error:"</SPAN><SPAN class="punctuation token">,</SPAN> error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN>
id<SPAN class="operator token">=</SPAN><SPAN class="string token">"select-by-polygon"</SPAN>
<SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget esri-widget--button esri-widget esri-interactive"</SPAN>
title<SPAN class="operator token">=</SPAN><SPAN class="string token">"Select features by polygon"</SPAN>
<SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-icon-checkbox-unchecked"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"info"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"info"</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>b<SPAN class="operator token">></SPAN>Instructions<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>b<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>br <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>ul<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>li<SPAN class="operator token">></SPAN>
Select features using select by polygon tool<SPAN class="punctuation token">.</SPAN> Attributes <SPAN class="keyword token">of</SPAN> selected
features will be displayed here<SPAN class="punctuation token">.</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>li<SPAN class="operator token">></SPAN>
Click on a row to select a feature associated <SPAN class="keyword token">with</SPAN> it or click on a
feature to display its popup<SPAN class="punctuation token">.</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>ul<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"gridDisplay"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"info"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">"featureCount"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"grid"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
