Hello! I would like to create a data extraction function for the feature layers in my map. The online sample http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ExtractData allows the user to clip the features and download data. However, is there a way to download the data based on features selected in featuredatagrid? I would like users to select features in the data grid and extract their attributes by clicking a "download" button. Can anyone tell me how the xaml and code-behind should look like? In specific, what part of the c# code in the sample controls the actual extraction (not clipping or drawing) method? And how should I call it in xaml?My current data grid xaml code looks like this:<esri:FeatureDataGrid Grid.Row="2"
x:Name="MyDataGrid"
GraphicsLayer='{Binding ElementName=QueryComboBox, Path=SelectedItem}'
AutoGenerateColumns='True'></esri:FeatureDataGrid>
The c# code of the sample is this:using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Threading;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Symbols;
using ESRI.ArcGIS.Client.Tasks;
namespace ArcGISSilverlightSDK
public partial class ExtractData : UserControl
private Draw _drawObject;
Geoprocessor _geoprocessorTask;
private DispatcherTimer _processingTimer;
Stream _streamedDataFile;
GraphicsLayer _graphicsLayer;
public ExtractData()
InitializeComponent();
_processingTimer = new System.Windows.Threading.DispatcherTimer();
_processingTimer.Interval = new TimeSpan(0, 0, 0, 0, 800);
_processingTimer.Tick += ProcessingTimer_Tick;
_geoprocessorTask = new Geoprocessor("http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/Incident_Data_Extraction/GPServer/Extract Data Task");
_geoprocessorTask.GetServiceInfoCompleted += _geoprocessorTask_GetServiceInfoCompleted;
_geoprocessorTask.Failed += _geoprocessorTask_Failed;
_geoprocessorTask.UpdateDelay = 5000;
_geoprocessorTask.JobCompleted += _geoprocessorTask_JobCompleted;
_geoprocessorTask.GetResultDataCompleted += _geoprocessorTask_GetResultDataCompleted;
_geoprocessorTask.GetServiceInfoAsync();
_drawObject = new Draw(MyMap)
LineSymbol = LayoutRoot.Resources["CustomAnimatedRedLineSymbol"] as LineSymbol,
FillSymbol = LayoutRoot.Resources["CustomAnimatedRedFillSymbol"] as FillSymbol
_drawObject.DrawComplete += MyDrawObject_DrawComplete;
_graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
private void DrawPolygon_Click(object sender, RoutedEventArgs e)
_graphicsLayer.ClearGraphics();
if (FreehandCheckBox.IsChecked.Value)
_drawObject.DrawMode = DrawMode.Freehand;
else
_drawObject.DrawMode = DrawMode.Polygon;
_drawObject.IsEnabled = true;
private void FreehandCheckBox_Checked(object sender, RoutedEventArgs e)
else
void _geoprocessorTask_GetServiceInfoCompleted(object sender, GPServiceInfoEventArgs e)
LayersList.ItemsSource = e.GPServiceInfo.Parameters.FirstOrDefault(p => p.Name == "Layers_to_Clip").ChoiceList as object[];
Formats.ItemsSource = e.GPServiceInfo.Parameters.FirstOrDefault(p => p.Name == "Feature_Format").ChoiceList as object[];
if (Formats.ItemsSource != null && Formats.Items.Count > 0)
Formats.SelectedIndex = 0;
private void MyDrawObject_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args)
if (LayersList.SelectedItem == null)
MessageBox.Show("Please select layer(s) to extract");
(MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer).ClearGraphics();
return;
Geometry filterGeometry = args.Geometry;
if (args.Geometry is Polyline)
Polyline freehandLine = args.Geometry as Polyline;
freehandLine.Paths[0].Add(freehandLine.Paths[0][0].Clone());
filterGeometry = new Polygon() { SpatialReference = MyMap.SpatialReference };
(filterGeometry as Polygon).Rings.Add(freehandLine.Paths[0]);
ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
Geometry = filterGeometry
_graphicsLayer.Graphics.Add(graphic);
_drawObject.IsEnabled = false;
ProcessingTextBlock.Visibility = Visibility.Visible;
_processingTimer.Start();
List<GPParameter> parameters = new List<GPParameter>();
var strLayerList = new List<GPString>();
foreach (var itm in LayersList.SelectedItems)
strLayerList.Add(new GPString(itm.ToString(), itm.ToString()));
parameters.Add(new GPMultiValue<GPString>("Layers_to_Clip", strLayerList));
parameters.Add(new GPFeatureRecordSetLayer("Area_of_Interest", _graphicsLayer.Graphics[0].Geometry));
parameters.Add(new GPString("Feature_Format", Formats.SelectedValue.ToString()));
_geoprocessorTask.SubmitJobAsync(parameters);
void _geoprocessorTask_JobCompleted(object sender, JobInfoEventArgs e)
if (e.JobInfo.JobStatus != esriJobStatus.esriJobSucceeded)
MessageBox.Show("Extract Data task failed to complete");
return;
_geoprocessorTask.GetResultDataAsync(e.JobInfo.JobId, "Output_Zip_File");
void _geoprocessorTask_GetResultDataCompleted(object sender, GPParameterEventArgs ev1)
if (ev1.Parameter is GPDataFile)
GPDataFile ClipResultFile = ev1.Parameter as GPDataFile;
if (String.IsNullOrEmpty(ClipResultFile.Url))
return;
MessageBoxResult res = MessageBox.Show("Data file created. Would you like to download the file?", "Geoprocessing Task Success", MessageBoxButton.OKCancel);
if (res == MessageBoxResult.OK)
WebClient webClient = new WebClient();
webClient.OpenReadCompleted += (s, ev) =>
_streamedDataFile = ev.Result;
SaveFileButton.Visibility = Visibility.Visible;
ProcessingTextBlock.Text = "Download completed. Click on 'Save data file' button to save to disk.";
webClient.OpenReadAsync(new Uri((ev1.Parameter as GPDataFile).Url), UriKind.Absolute);
else
ProcessingTextBlock.Text = "";
ProcessingTextBlock.Visibility = Visibility.Collapsed;
SaveFileButton.Visibility = Visibility.Collapsed;
_processingTimer.Stop();
void _geoprocessorTask_Failed(object sender, TaskFailedEventArgs e)
MessageBox.Show("Extract data task failed: " + e.Error.Message);
private void ResetButton_Click(object sender, System.Windows.RoutedEventArgs e)
void ProcessingTimer_Tick(object sender, EventArgs e)
if (ProcessingTextBlock.Text.Length > 20 || !ProcessingTextBlock.Text.StartsWith("Processing"))
ProcessingTextBlock.Text = "Processing.";
else
ProcessingTextBlock.Text = ProcessingTextBlock.Text + ".";
private void SaveFileButton_Click(object sender, RoutedEventArgs e)
SaveFileDialog dialog = new SaveFileDialog();
dialog.DefaultFileName = "Output.zip";
dialog.Filter = "Zip file (*.zip)|*.zip";
bool? dialogResult = dialog.ShowDialog();
if (dialogResult != true) return;
try
using (Stream fs = (Stream)dialog.OpenFile())
_streamedDataFile.CopyTo(fs);
fs.Flush();
fs.Close();
ProcessingTextBlock.Text = "Output file saved successfully!";
_streamedDataFile = null;
catch (Exception ex)
MessageBox.Show("Error saving file :" + ex.Message);
Thanks a lot in advance!
