ArcGIS SDK for Android: 10.2.3
Android SDK: Level 11
In eclipse, load the HelloWorld sample code to AVD with the exception message below:
07-24 21:04:15.685: V/TLINE(453): new: android.text.TextLine@405be400
07-24 21:04:15.815: D/libEGL(453): egl.cfg not found, using default config
07-24 21:04:15.815: D/libEGL(453): loaded /system/lib/egl/libGLES_android.so
07-24 21:04:15.825: W/dalvikvm(453): threadid=10: thread exiting with uncaught exception (group=0x40014760)
07-24 21:04:15.895: E/AndroidRuntime(453): FATAL EXCEPTION: GLThread 11
07-24 21:04:15.895: E/AndroidRuntime(453): java.lang.IllegalArgumentException: No configs match configSpec
07-24 21:04:15.895: E/AndroidRuntime(453): at com.esri.android.map.MapSurface$a.chooseConfig(Unknown Source)
07-24 21:04:15.895: E/AndroidRuntime(453): at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:981)
07-24 21:04:15.895: E/AndroidRuntime(453): at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1326)
07-24 21:04:15.895: E/AndroidRuntime(453): at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1180)
07-24 21:04:16.195: D/dalvikvm(453): GC_CONCURRENT freed 258K, 7% free 5554K/5959K, paused 3ms+21ms
07-24 21:04:17.395: D/dalvikvm(453): GC_CONCURRENT freed 303K, 8% free 5667K/6151K, paused 8ms+2ms
07-24 21:09:15.976: I/Process(453): Sending signal. PID: 453 SIG: 9
Remove MapView objects it can run.
So this is caused by ArcGIS SDK. How to solve it?
