I have created a Python application that I would like to distribute within our organization. I have created a frozen exe using cx_Freeze, but the exe crashes in GeoprocessingLib.dll. I have isolated the problem to a very simple example. Here is the Python code:
test.py:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Hello world!'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
And here is the command to create the frozen exe:
cxfreeze test.py
Here are the error details from Windows Event Viewer:
Faulting application name: test.exe, version: 0.0.0.0, time stamp: 0x0001e4e4
Faulting module name: GeoprocessingLib.dll, version: 10.1.1.3300, time stamp: 0x52e02880
Exception code: 0xc0000005
Fault offset: 0x00154eda
Faulting process id: 0x1804
Faulting application start time: 0x01d250b28e4a7d73
Faulting application path: Z:\lethpy-trees\lethpy\gistools\dist\test.exe
Faulting module path: C:\Users\11157\AppData\Local\Temp\_MEI50322\GeoprocessingLib.dll
Report Id: cdb968dd-bca5-11e6-82d8-3417ebaaaccc
Faulting package full name:
Faulting package-relative application ID:
I have tried both cx_Freeze and pyInstaller to create the standalone exe, but the problem is the same. We are using ArcGIS 10.1 SP1.
Any help would be appreciated.
