In my mobile app, I am creating a new featureCollectionLayer by copying the selected features from a feature layer to a FeatureCollectionTable as follows-
private async Task CreateNewFeatureCollection(FeatureQueryResult features, Renderer renderer)
// Create the schema for the table
var fields = features.First().FeatureTable.Fields;
// Instantiate FeatureCollectionTables with schema and geometry type
FeatureCollectionTable featureCollectionTable = new FeatureCollectionTable(fields, features.GeometryType, SpatialReferences.WebMercator);
// Set rendering for each table
featureCollectionTable.Renderer = renderer;
foreach (Feature feature in features)
//Debug.WriteLine(feature.GetAttributeValue("SURTYPE").ToString());
Feature newFeature = featureCollectionTable.CreateFeature(feature.Attributes, feature.Geometry);
await featureCollectionTable.AddFeatureAsync(newFeature);
FeatureCollection featuresCollection = new FeatureCollection();
featuresCollection.Tables.Add(featureCollectionTable);
// Create a FeatureCollectionLayer
FeatureCollectionLayer collectionLayer = new FeatureCollectionLayer(featuresCollection);
// When the layer loads, zoom the map centered on the feature collection
await collectionLayer.LoadAsync();
// Add the layer to the Map's Operational Layers collection
if(features.GeometryType == GeometryType.Point)
Map.OperationalLayers.Add(collectionLayer);
else
if (Map.OperationalLayers.Count > 1)
Map.OperationalLayers.Insert(1, collectionLayer);
else
I use a unique value renderer for featureCollectionTable as follows-
public Renderer GetTrailsQueryRenderer()
UniqueValueRenderer renderer = new UniqueValueRenderer();
renderer.FieldNames.Add("SURTYPE");
SimpleLineSymbol hardLineSymbol = new SimpleLineSymbol(SimpleLineSymbolStyle.Solid, System.Drawing.Color.FromArgb(255, 51, 204), 2);
SimpleLineSymbol softLineSymbol = new SimpleLineSymbol(SimpleLineSymbolStyle.Dash, System.Drawing.Color.FromArgb(255, 51, 204), 2);
// Add values to the renderer: define the label, description, symbol, and attribute value for each
renderer.UniqueValues.Add(
new UniqueValue(" ", "Hard Surface", hardLineSymbol, "HardSurface"));
new UniqueValue(" ", "Soft Surface", softLineSymbol, "SoftSurface"));
// Set the default region fill symbol (transparent with no outline) for regions not explicitly defined in the renderer
renderer.DefaultSymbol = hardLineSymbol;
return renderer;
However the renderer doesn't work for unique values and only shows the hardLineSymbol because it has been set as the default symbol as well. I have checked the attributes of features and they look good its the renderer it seems that is not changing shapes for unique values.
Apurva
