I wonder if it is possible to use the labels renderers defined in a .mxd published as a Map Service (Feature Access enabled) for a FeatureLayer with the javascript API v4.3 just like it works with the geometry renderer?
I define a featureLayer like this:
var organismesLayer = new FeatureLayer({
url: "https://infogeo.education.gouv.qc.ca/arcgis/rest/services/SandBox_Maxime/GDUNO/MapServer/1",
labelsVisible: true
});<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>In the map, I see the layer style is the same than in the .mxd, but the labels are not visible. Do I have to define the LabelClass manually in the javascript code?
Is there a way to get the label renderers from the Map Service?
