Any help with the error message below would be appreciated.
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> outbufferpath
featureClassList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> featureClass <SPAN class="keyword token">in</SPAN> featureClassList<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>Clip<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">,</SPAN> outrasterpath <SPAN class="operator token">+</SPAN> featureClass<SPAN class="punctuation token">,</SPAN> featureClass<SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">3.402823e+38</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ClippingGeometry"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MAINTAIN_EXTENT"</SPAN><SPAN class="punctuation token">)</SPAN>
Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
File <SPAN class="string token">"<string>"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">15215</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> Clip
<SPAN class="keyword token">raise</SPAN> e
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">15212</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> Clip
retval <SPAN class="operator token">=</SPAN> convertArcObjectToPythonObject<SPAN class="punctuation token">(</SPAN>gp<SPAN class="punctuation token">.</SPAN>Clip_management<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>gp_fixargs<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>in_raster<SPAN class="punctuation token">,</SPAN> rectangle<SPAN class="punctuation token">,</SPAN> out_raster<SPAN class="punctuation token">,</SPAN> in_template_dataset<SPAN class="punctuation token">,</SPAN> nodata_value<SPAN class="punctuation token">,</SPAN> clipping_geometry<SPAN class="punctuation token">,</SPAN> maintain_clipping_extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
File <SPAN class="string token">"c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py"</SPAN><SPAN class="punctuation token">,</SPAN> line <SPAN class="number token">496</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="keyword token">lambda</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">lambda</SPAN> <SPAN class="operator token">*</SPAN>args<SPAN class="punctuation token">:</SPAN> val<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>gp_fixargs<SPAN class="punctuation token">(</SPAN>args<SPAN class="punctuation token">,</SPAN> <SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcgisscripting<SPAN class="punctuation token">.</SPAN>ExecuteError<SPAN class="punctuation token">:</SPAN> Failed to execute<SPAN class="punctuation token">.</SPAN> Parameters are <SPAN class="operator token">not</SPAN> valid<SPAN class="punctuation token">.</SPAN>
ERROR <SPAN class="number token">000445</SPAN><SPAN class="punctuation token">:</SPAN> Extension <SPAN class="keyword token">is</SPAN> invalid <SPAN class="keyword token">for</SPAN> the output raster format<SPAN class="punctuation token">.</SPAN>
Failed to execute <SPAN class="punctuation token">(</SPAN>Clip<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
