We are doing some testing of the SDK Runtime using C# & WPF. I started with the "Display point, line, and polygon graphics" tutorial and added the following code:
private void DisplayPoints(SqlGeography geometry, Color pointColor, bool displayOnMap = true)
var numGeometries = geometry.STNumGeometries();
for (int i = 0; i < geometry.STNumGeometries(); i++)
var polygonPoints = new Esri.ArcGISRuntime.Geometry.PointCollection(SpatialReferences.Wgs84);
var numSTPoints = geometry.STGeometryN(i + 1).STNumPoints();
for (int j = 1; j <= numSTPoints; j++)
var point = geometry.STPointN(j);
pointSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Circle, pointColor, 5);
pointSymbol.Outline = new SimpleLineSymbol(SimpleLineSymbolStyle.Null, pointColor, 1);
var pointGraphic = new Graphic(new MapPoint((double)point.Long, (double)point.Lat, SpatialReferences.Wgs84), pointSymbol);
MapGraphics.Graphics.Add(pointGraphic);
I am loading some geography data from a db and displaying on the map. Everything works except the points are always the same color no matter what color is passed in. I determined that whatever is the last color of the last point added wins.
If I want to add a bunch of points (or polygons) what is the proper way to set the colors if I need them to be different.
