Hi
I'm trying to set up a date query using the Query widget in a Web AppBuilder app but the query doesn't return any results...can't figure out why. I get a message saying 'query failed!' and 'number of features found: 0', when there should definitely be some results returned.
So far I've checked/ tried a few things:
- The layer I'm using has time enabled
- Filtering by date works fine within the web map
- When setting the query up within the Query widget it recognises that the field I'm using is in Date format because it lets me set the default to search between two dates
- When I look at the attribute table in the app it sorts the date field correctly
Any suggestions for other things I can try?
Thanks for your help!
