Many Points to Few...
Hello, i am unsure if this is the correct place for this but it is an arcpy problem and i am new here, feel free to redirect me.
Anyway I am trying to reduce a large dataset of about 4.6 Million points down to a few hundred thousand by removing duplicates. I have been running this in arcpy as its more stable and faster, and who doesn't love some programming.
So far my script is less than optimal but essentially it;
Clips points by New Zealand regions
clips points by mesh-blocks within this region
deletes identical points within these mesh-blocks by buffering 20 metres out from the '*shape'
appends it to a list of new points.
It works quite well and am about halfway however it aborts at the same point everytime,
"2181500
11.95% Complete
2145600
aborted"
i have tried repair geometry for all datasets and have tried changing from meshblocks to area-units but to no avail.Here is most of the code. Cheers in advance!
"""Run check geometry on regions"""
gp.addmessage("Checking Geometries")
arcpy.CheckGeometry_management ([NZAreaUnits,TAs,"points"], "ManyPointsTable")
count = arcpy.GetCount_management("ManyPointsTable")
gp.addmessage(str(count) + " errors found")
if count >= 1:
gp.addmessage("...Repairing ")
arcpy.RepairGeometry_management (NZAreaUnits)
arcpy.RepairGeometry_management (TAs)
arcpy.RepairGeometry_management ("Points")
else:
gp.addmessage("Search Cursor")
"""Create Search cursor for Large Regions"""
seaCur = arcpy.SearchCursor(TAs)
region = 8
number = float(arcpy.GetCount_management(TAs).getOutput(0))
"""Make Small Features Layer and Select if they contain points then clip and use for Small regions"""
gp.addmessage("Making Feature Layer with only valued Features")
arcpy.MakeFeatureLayer_management(NZAreaUnits, "areunits")
arcpy.SelectLayerByLocation_management ( "areunits", "WITHIN_A_DISTANCE", "points" , "20 METERS" )
arcpy.FeatureClassToFeatureClass_conversion ("areunits", "C:\\Users\\Cody\\Documents\\GISData\\AvlSH2013Take2.gdb", "ClippedAU")
NZAreaUnits ="ClippedAU"
#Regional Clip
for Regions in seaCur:
percentcomplete = float((region/number)* 100)
region += 1
#Clip the features by row
geom = Regions.shape
gp.addmessage("Running Clip on -" + Regions.getValue("NAME"))
arcpy.Clip_analysis("points" , geom , "Clip")
arcpy.Clip_analysis(NZAreaUnits , geom , "AUClip")
gp.addmessage("Starting Region" + " "+str(region))
SearchCur = arcpy.SearchCursor("AUClip")
#Create New Dataset and name
outset = "Finalset" + str(region)
arcpy.CreateFeatureclass_management("C:\\Users\\Cody\\Documents\\GISData\\AvlSH2013Take2.gdb", outset, "POINT", "points", "DISABLED", "DISABLED", "points")
number1 = float(arcpy.GetCount_management("AUClip").getOutput(0))
gp.addmessage(str("{0:.2f}".format(round(percentcomplete,2))) + "% Total Complete")
AU = 0
#AU Clip
for AreUnit in SearchCur:
AU += 1
percomplete = float((AU/number1)* 100)
#Clip
geom = AreUnit.shape
gp.addmessage(AreUnit.getValue("MB06"))
arcpy.Clip_analysis("Clip" , geom , "Sclip")
#Delete Identical
arcpy.MakeFeatureLayer_management("Sclip", "Layer")
arcpy.DeleteIdentical_management("Layer", "Shape", "20 METERS")
#Merge Data
arcpy.Merge_management(["Layer", outset ], "Merge")
arcpy.CopyFeatures_management ("Merge", outset)
gp.addmessage(str("{0:.2f}".format(round(percomplete,2))) + "% Complete")
