I am trying to publish vehicle routing problem service on ArcGIS for Server.
I performed the following steps:
- I created Vehicle Routing Problem layer based on my network dataset using ArcMap
- I tested it and it is working fine on ArcMap
- Then I published the mxd as a service and enabled network analysis capability.
But I couldn't find the service under /arcgis/rest/services/MyNetwork/NAServer
However if I did the same steps for routing layer, it works fine and I can find it at /arcgis/rest/services/MyNetwork/NAServer/Route
