Hi all, My script is working except the field mappings. When I remove that parameter from the spatial join, it runs fine (but doesn't include the desired field in the output). When I add the fieldMappings parameter to the spatial join, the script throws the beloved ERROR 999999: Error executing function.Thus, I know the problem isolated to how I am imputing the fieldMappings parameter which also makes me believe it is a basic misunderstanding on my part regarding how to utilize field mappings. Here is a code snippet of the issue:
mapFields = ["ITEM_ID", "PRIME_GEO"]
fieldMappings = arcpy.FieldMappings()
for mapField in mapFields:
fieldMap = arcpy.FieldMap()
fieldMap.addInputField(aoi, mapField)
fieldMappings.addFieldMap(fieldMap)
arcpy.SpatialJoin_analysis(aoi, "buildingLyr", buildingOutput, "JOIN_ONE_TO_ONE", "KEEP_COMMON", fieldMappings, "COMPLETELY_WITHIN", "", "")
PS. Of the two tables involved in the join, I only really need to retain the ITEM_ID (and resulting count) field after the join. If there is a better way to do this than field mapping, please share your idea!
