Hi everyone,Simple but frustrating problem:Prior to arcAddinx, there was no problem choosing to have Image / Text or Both for any button when a toolbar was loaded using the following code below triggered off the ENABLED using ESRICommandStyles. (IToolbarDef) Public Sub SetAsIconAndText()
' Make sure button is showing Icon And Text
Dim pUID As New UID
pUID.Value = "{F53B91E1-C520-41a7-941C-686AA071D1A2}" ' Toolbar GUID
Dim pCommandBar As ESRI.ArcGIS.Framework.ICommandBar
pCommandBar = m_application.Document.CommandBars.Find(pUID, True, False)
Dim i As Integer
If Not pCommandBar Is Nothing Then
For i = 0 To pCommandBar.Count - 1
If pCommandBar.Item(i).Name = "FocusCorp_FocusEllipse" Then ' use the Property NAME of the button
pCommandBar.Item(i).Style = esriCommandStyles.esriCommandStyleIconAndText
Exit For
End If
End If
End Sub
I am aware that a user can AFTER the fact customize, but why would ESRI have left this functionality out with Addin XML?Is there anyone that has found the means to control what each button displays on created toolbars when using Addins as far as Image and Caption? Suggestions appreciated,vb.netThanks
