I'm using the Search tool to allow users to enter their address and be taken to their property of interest. This is for a parcel viewer application with over 800,000 records. Ideally, when the user enters their address in the Search, they will quickly be zoomed to their location of interest. However, right now it takes about 13 seconds for the Search to retrieve their address and zoom to the correct address. It's worth noting that all of the functionality is working (ie, the map eventually zooms to the location that was entered), it's just very slow.
The parcel layer that is being searched is the same parcel layer that is displayed on the map (called parcelLyr in the below code). Below is the code for the search tool:
<SPAN class="comment token">//Create search tool to search addresses</SPAN>
<SPAN class="keyword token">const</SPAN> searchTool <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> myView<SPAN class="punctuation token">,</SPAN>
sources<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
layer<SPAN class="punctuation token">:</SPAN> parcelLyr
searchFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"propstreet"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fullAdd2"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
displayField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fullAdd2"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"LayerSearchSource"</SPAN><SPAN class="punctuation token">,</SPAN>
placeholder<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"example: 500 Griswold"</SPAN><SPAN class="punctuation token">,</SPAN>
exactMatch<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
suggestionsEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
autoNavigate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
resultGraphicEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN>
container<SPAN class="punctuation token">:</SPAN> addressSearchBar<SPAN class="punctuation token">,</SPAN>
includeDefaultSources<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
popupEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
locationEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
searchAllEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Is there something I can do to ensure that the correct address is retrieved more quickly?
Paul
