I'm creating a widget which contains some radio buttons, and I need to figure out how to trigger the appropriate code when the radio button selection changes. Here's a simple mockup of the app:
Widget.html contains the radio buttons, which each have the class rdoButton:
<div>
<form>
<input type="radio" id="rdoYes" class="rdoButton" name="radio1" value="yes" />Yes
<input type="radio" id="rdoNo" class="rdoButton" name="radio1" value="no" />No
</form>
</div>
Within Widget.js I'm trying to set the listener at the class level, and also at the ID level, and trying the change and click events:
onChangeRadio<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"change radio button"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
_bindEvents<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">own</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>rdoTheme<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"change"</SPAN><SPAN class="punctuation token">,</SPAN>
lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>_onChangeRadio<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">own</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>rdoYes<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Clicking on the radio buttons doesn't fire the onChangeRadio function in either case. How can I set a listener for these radio buttons? Thanks
Edit: looking at the Scalebar widget, I'm trying to emulate the code used in its Settings section:
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"unit-item"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>point<SPAN class="operator token">=</SPAN><SPAN class="string token">"englishNode"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"jimu/dijit/RadioBtn"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"group:'sclebarUnit'"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>label <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"jimu-leading-margin025"</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>nls<SPAN class="punctuation token">.</SPAN>english<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>label<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">own</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>englishNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'selectUnit'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'english'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I can successfully trigger the Click function using this approach, but I can't see how to generate the radio buttons - only the labels show.
