I created a survey with Survey123 Connect using an existing feature layer in ArcGIS Online. I want to be able to click on a polygon in that feature layer and launch the survey from a link in the popup and have the survey responses entered into the attributes for polygon that was clicked.
The survey works, except, it creates a new record in the attribute table with a new GlobalID instead of filling in the attributes of the existing polygon. Here is the link that I have in the popup:
https://survey123.arcgis.com/share/5d793c29f58844f089d8d4dea0db0867?mode=edit&globalId=GlobalID
I also tried curly brackets around “GlobalID” and it does the same thing.
Is it possible to do this?
