Hi Everyone, I am trying to create a very simple network dataset from a simple polyline shapefile. I can do this easily using ArcCatalog. ArcCatalog shows the conversion settings in a summary as following:Name: Street_sim_ND
Type: Shapefile-Based Network Dataset
Sources:
Edge Sources:
Street_sim
Connectivity:
Group 1:
Edge Connectivity:
Street_sim (End Point)
Elevation Model: None
Attributes:
Length:
Usage Type: Cost
Data Type: Double
Units Type: Feet
Use by Default: True
Source Attribute Evaluators:
Street_sim (From-To): Field
Language: VBScript
Expression: [Shape]
Street_sim (To-From): Field
Language: VBScript
Expression: [Shape]
Default Attribute Evaluators:
Default Edges: Constant = 0
Default Junctions: Constant = 0
Directions:
Directions Ready: No
-Length Attribute RequiredHowever, my attempts to do this programmatically using C# have run into problem. I get a COMException error. Here's my code. It crashed out at the field evaluator bit of the code, highlighted in red bold. Note that I read in the shapefile name as an argument to the method that runs the code below:
string shpName = shapefilename with full path;
// Create a new empty data element for a buildable network dataset.
IDENetworkDataset2 deNetworkDataset = new DENetworkDatasetClass();
deNetworkDataset.Buildable = true;
// Open the shapefile and cast to the IGeoDataset interface.
IWorkspaceFactory workspaceFactory = new ShapefileWorkspaceFactoryClass();
//IWorkspace workspace = workspaceFactory.OpenFromFile(@C:\Program Files\ArcGIS\DeveloperKit\SamplesNET\data\CreateNetworkDataset,0);
IWorkspace workspace = workspaceFactory.OpenFromFile(@System.IO.Path.GetDirectoryName(shpName), 0);
IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;
IFeatureClass featureClass = featureWorkspace.OpenFeatureClass(@System.IO.Path.GetFileNameWithoutExtension(shpName));
IGeoDataset geoDataset = (IGeoDataset)featureClass;
// Copy the shapefile's extent and spatial reference to the network dataset data element.
IDEGeoDataset deGeoDataset = (IDEGeoDataset)deNetworkDataset;
deGeoDataset.Extent = geoDataset.Extent;
deGeoDataset.SpatialReference = geoDataset.SpatialReference;
// Name - Specify the name of the network dataset //
IDataElement dataElement = (IDataElement)deNetworkDataset;
dataElement.Name = "Streets_ND";
// Elevation Model - Specify elevation model of the network //
deNetworkDataset.ElevationModel = esriNetworkElevationModel.esriNEMNone;
// Specify the network dataset's global turn policy
//deNetworkDataset.SupportsTurns = false;
// Source and Connectivity//
// Create a new EdgeFeatureSource object and point it to the Streets shapefile.
IEdgeFeatureSource streetsEdgeFeatureSource = new EdgeFeatureSourceClass();
INetworkSource streetsNetworkSource = (INetworkSource)streetsEdgeFeatureSource;
streetsNetworkSource.Name = System.IO.Path.GetFileNameWithoutExtension(shpName);
streetsNetworkSource.ElementType = esriNetworkElementType.esriNETEdge;
// Set the connectivity settings for the edge feature source.
streetsEdgeFeatureSource.UsesSubtypes = false;
streetsEdgeFeatureSource.ClassConnectivityGroup = 1;
streetsEdgeFeatureSource.ClassConnectivityPolicy = esriNetworkEdgeConnectivityPolicy.esriNECPEndVertex;
// Add the EdgeFeatureSource object to the data element as a source in the network dataset.
IArray sourceArray = new ArrayClass();
sourceArray.Add(streetsEdgeFeatureSource);
deNetworkDataset.Sources = sourceArray;
// Attributes
IArray attributeArray = new ArrayClass();
IEvaluatedNetworkAttribute lengthEvaluatedNetworkAttribute = new EvaluatedNetworkAttributeClass();
INetworkAttribute2 lengthNetworkAttribute2 = (INetworkAttribute2)lengthEvaluatedNetworkAttribute;
lengthNetworkAttribute2.Name = "Length";
lengthNetworkAttribute2.UsageType = esriNetworkAttributeUsageType.esriNAUTCost;
lengthNetworkAttribute2.DataType = esriNetworkAttributeDataType.esriNADTDouble;
lengthNetworkAttribute2.Units = esriNetworkAttributeUnits.esriNAUFeet;
lengthNetworkAttribute2.UseByDefault = true;
// Create evaluator objects and set them on the EvaluatedNetworkAttribute object.
INetworkFieldEvaluator lengthFTNetworkFieldEvaluator = new NetworkFieldEvaluatorClass();
lengthFTNetworkFieldEvaluator.SetExpression("[Shape]", "");
INetworkEvaluator lengthFTNetworkEvaluator = (INetworkEvaluator)lengthFTNetworkFieldEvaluator;
lengthEvaluatedNetworkAttribute.set_Evaluator(streetsNetworkSource, esriNetworkEdgeDirection.esriNEDNone, lengthFTNetworkEvaluator);
INetworkFieldEvaluator lengthTFNetworkFieldEvaluator = new NetworkFieldEvaluatorClass();
lengthTFNetworkFieldEvaluator.SetExpression("[Shape]", "");
INetworkEvaluator lengthTFNetworkEvaluator = (INetworkEvaluator)lengthTFNetworkFieldEvaluator;
lengthEvaluatedNetworkAttribute.set_Evaluator(streetsNetworkSource, esriNetworkEdgeDirection.esriNEDNone, lengthTFNetworkEvaluator);
INetworkConstantEvaluator lengthNetworkConstantEvaluator = new NetworkConstantEvaluatorClass();
lengthNetworkConstantEvaluator.ConstantValue = 0;
INetworkEvaluator lengthConstantNetworkEvaluator = (INetworkEvaluator) lengthNetworkConstantEvaluator;
lengthEvaluatedNetworkAttribute.set_DefaultEvaluator(esriNetworkElementType.esriNETEdge, lengthConstantNetworkEvaluator);
lengthEvaluatedNetworkAttribute.set_DefaultEvaluator(esriNetworkElementType.esriNETJunction, lengthConstantNetworkEvaluator);
// Add the attribute to the array.
attributeArray.Add(lengthEvaluatedNetworkAttribute);
deNetworkDataset.Attributes = attributeArray;
// Create a new UID that references the NetworkDatasetWorkspaceExtension.
UID ndWorkspaceExtensionUID = new UIDClass();
ndWorkspaceExtensionUID.Value = "esriGeoDatabase.NetworkDatasetWorkspaceExtension";
// Get the workspace extension and create the network dataset based on the data element.
IWorkspaceExtensionManager workspaceExtensionManager = (IWorkspaceExtensionManager)workspace;
IWorkspaceExtension workspaceExtension = workspaceExtensionManager.FindExtension(ndWorkspaceExtensionUID);
IDatasetContainer2 datasetContainer2 = (IDatasetContainer2)workspaceExtension;
IDEDataset deDataset = (IDEDataset)deNetworkDataset;
INetworkDataset networkDataset = (INetworkDataset) datasetContainer2.CreateDataset(deDataset);
// Once the network dataset is created, build it.
INetworkBuild networkBuild = (INetworkBuild)networkDataset;
networkBuild.BuildNetwork(geoDataset.Extent);I have basically (thoughtlessly!) recycled ESRI's sample code for something similar but obviously unable to do it properly. Any suggestions will be most appreciated.Thanks,Sanj.
