I have a layout in ArcGISPro with three map frames (CONUS, AK, and HI) all pointing to the same map and data sources. However, the scale in the AK map frame is much smaller (1:5 mil) than the other two (1:3 mil) so I can fit all of AK on my layout. Unfortunately, my point symbols appear smaller on my AK data frame than on the others. How to I force a renderer to display the same size for every point regardless of scale (say 8 pixles no matter the scale). Strangely, point symbol template in the Layers tab, toggling "Respect frame" and "Scale proportionally" doesn't seem to make a difference. Is this possible / anyone know how to achieve this? In the attached image, the two points with the red line drawn between them should be the same size, but due to the scale difference in the map frames, the one on AK is smaller.
Thanks!
