Hello community,
I already have a workaround for my problem, but I'm curious if there is a more elegant way to handle it.
I receive messages on a UDP port as comma comma-separated values (25 fields). These are never complete. Most of the time I receive geometric information only (ID, coordinates, speed). Occasionally I receive additional information for my IDs (ID, name, measurements, destination).
## Geometrics
#ID, Ycoord, Xcoord, speed, ..., time
000123,9.1543,55.7552,235.89,,,,,,,,,,,,,,,,,,,,05/31/2019, 08:38:10
000123,9.1544,55.7553,250.30,,,,,,,,,,,,,,,,,,,,05/31/2019, 08:38:15
## Additional Information
#ID, ... , name, ... measurements ..., destination, time
000123,,,,,,,,,,Vehicle1,74,,,,8,1,6,5,3,0,6.40,Destination2,05/31/2019, 08:38:00
000123,,,,,,,,,,,74,108,12,10,8,1,,,,,,,05/31/2019, 08:38:30 <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The geometrics are filtered from the rest in GeoEvent Server. The idea is to later enrich it with the additional information.
Normally, I would Update a feature layer with the additional information and use the hosted feature layer to enrich the geometric data. However, as you can see the data contains empty/nan values, which leads to crucial information (Name, Destination) occasionally being unavailable when updating+enriching.
- How can I update a feature layer while ignoring single empty/nan attributes?
I'm sincerely thankful to any suggestions.
kind regards, Markus
PS:
For now, I'm writing everything to csv, and using a python script to group the data, export it to csv/json,and load it to GeoEvent Server. Which seems to me like a unnecessary loop.
df2 <SPAN class="operator token">=</SPAN> df2<SPAN class="punctuation token">.</SPAN>groupby<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'ID'</SPAN><SPAN class="punctuation token">,</SPAN> as_index<SPAN class="operator token">=</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>last<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
The function ignores NaN-values by default.
