I'm trying to follow the instructions for the installation of the SDK (pasted below).
Stages 1-3 went well.
Got stuck at stage 4 - there is no Setup.exe to be found. I've downloaded the SDK a couple of times.
Any idea how I proceed from here?
Thanks in advance.
Install the SDK on Windows
- Make sure your development machine meets the system requirements.
- Download and extract the SDK. Download the SDK for your operating system from the Downloads page.
- Install the Eclipse integrated development environment (IDE) before installing this SDK. For a list of supported IDEs, see the system requirements.
- Double-click the Setup.exe file at the top level of the extracted files you downloaded in step 2 to start the installation wizard. The ArcGIS Runtime SDK for Java installation wizard appears.
- Click Next.
- Follow the on-screen instructions. In the Select Features panel, you can change the default installation directory by clicking the Change button, then navigating to the desired directory. Make sure this directory is on your development machine and that you have write permissions to this directory. Ensure no other users are using the directory.
- On the last panel of the wizard, click Finish. The ArcGIS Runtime SDK for Java is now installed at the installation directory you chose in the previous step. You are now ready to install the Eclipse plug-in.
