Hello Forum,I have this intermittent problem, (happens about 60% of the time.) I have an extension (not addin) where I listen for a start editing eventIn the start editing I start other events listeners, specificaly activeviewevents item added, item removed and mapevents featureclass changed.The problem is often (60% of the time but never in debug mode) I get an exception when adding the event handlerSystem.Runtime.InteropServices.InvalidComObjectException: COM object that has been separated from its underlying RCW cannot be used.this is a snippet in the startediting event handler
m_actViewEvents = CType(m_map, IActiveViewEvents_Event)
Trace.WriteLine("active view events retrieved")
AddHandler m_actViewEvents.ItemAdded, AddressOf ItemAdded 'exception is thrown here
Trace.WriteLine("item added event handler added")
I set the m_map in the start editing. I tried casting the m_Editor.map to the Iactiveviewevents (better design), I tried setting the m_map from the editor, I tried using the document focus map. I tried declaring the m_Editor and m_map member vars as shared (static) I tried declaring the m_activeViewEvents as shared. As far as I know everything is done on the main thread.I would rather not populate the m_map variable before the edit session is started since the focus map could change.
