Hello,I'm trying to modify an interesting example from ESRI that shows some points on a map and only the visible ones that are on the screen in a DataGrid on the right. There is an InfoSymbol in the app but it's not connected to anything. I tried to connect it to a mouseOver event but I can't get it to open. Can somebody help?<?xml version="1.0" encoding="utf-8"?>
<mx:Application
xmlns:mx="http://www.adobe.com/2006/mxml"
xmlns:esri="http://www.esri.com/2008/ags"
layout="horizontal"
pageTitle="3 / query by extent"
initialize="initApp()">
<mx:Script>
<![CDATA[
import mx.effects.Glow;
import mx.events.EffectEvent;
import mx.events.ListEvent;
import com.esri.ags.Graphic;
import com.esri.ags.events.DrawEvent;
import com.esri.ags.events.ExtentEvent;
import com.esri.ags.geometry.Extent;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.tasks.Query;
import com.esri.ags.tasks.FeatureSet;
import mx.collections.ArrayCollection;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
import mx.managers.ToolTipManager;
private function initApp():void {
ToolTipManager.showDelay = 0;// Display immediately.
[Bindable] private var hashmapOfExistingGraphics : Object=new Object();
private function onExtentChange(event:ExtentEvent):void
query.geometry = myMap.extent;
queryTask.execute(query, new AsyncResponder( onResult, onFault ));
private function onResult( featureSet : FeatureSet, token : Object = null ) : void
for each ( var myGraphic : Graphic in featureSet.features )
// only add features that are not already in the graphics layer
var graphicID:String=myGraphic.attributes.HotSpot + "." + myGraphic.attributes.FID;
if ( ! hashmapOfExistingGraphics[graphicID] )
// New feature (not already added to graphics layer
hashmapOfExistingGraphics[graphicID]=1;
myGraphic.symbol = defaultSymbol;
myGraphic.id = graphicID;
myGraphic.toolTip = myGraphic.attributes.CITY_NAME;
myGraphicsLayer.add( myGraphic );
var extent : Extent = myMap.extent;
var graphic : Graphic;
var results : ArrayCollection = new ArrayCollection;
for (var i : Number = 0 ; i < myGraphicsLayer.numChildren ; i++)
graphic = myGraphicsLayer.getChildAt(i) as Graphic;
trace("GG:" + graphic.geometry );
if (extent.contains(MapPoint(graphic.geometry)))
results.addItem(graphic.attributes);
dg.dataProvider = results;
private function onFault( info : Object, token : Object = null ) : void
Alert.show( info.toString() );
private function onItemRollOver( event : ListEvent ) : void
var gr: Graphic = findGraphicByAttribute(event.itemRenderer.data)
gr.symbol = highlightedSymbol;
var glow:Glow = new Glow(gr);
glow.duration = 2000 ;
glow.alphaFrom = 1 ;
glow.alphaTo = 0 ;
glow.blurXFrom = 10 ;
glow.blurXTo = 0 ;
glow.blurYFrom = 20 ;
glow.blurYTo = 0 ;
glow.strength = 100;
glow.color = redFill.color;
glow.play();
private function onItemRollOut( event : ListEvent ) : void
findGraphicByAttribute(event.itemRenderer.data).symbol = defaultSymbol;
public function findGraphicByAttribute( attributes : Object ) : Graphic
for each( var graphic : Graphic in myGraphicsLayer.graphicProvider)
if ( graphic.attributes["CITY_NAME"] == attributes["CITY_NAME"])
return graphic;
return null;
public function findInList( graphic : Graphic ) : int
for each( var attributes : Object in dg.dataProvider )
if (attributes === graphic.attributes)
return (dg.dataProvider as ArrayCollection).getItemIndex(attributes)
return -1;
</mx:Script>
<esri:SimpleFillSymbol id="redFill" alpha="0.5" color="0xFF0000"/>
<!-- setup stuff -->
<esri:QueryTask id="queryTask" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0"/>
<esri:Query id="query" outFields="CITY_NAME, STATE_NAME, ELEVATION, FID" returnGeometry="true" />
<esri:SimpleMarkerSymbol id="defaultSymbol" color="0x0000FF" style="triangle" size="20" />
<esri:SimpleMarkerSymbol id="highlightedSymbol" color="0xFF0000" style="triangle" size="20" />
<esri:InfoSymbol id="myInfoSymbol">
<esri:infoRenderer>
<mx:Component >
<mx:VBox label="{data.CITY_NAME}" backgroundColor="0xEEEEEE">
<mx:Label text="Name: {data.CITY_NAME}"/>
<mx:Label text="State: {data.STATE_NAME}"/>
<mx:Label text="Elevation: {data.ELEVATION}"/>
</mx:VBox>
</mx:Component>
</esri:infoRenderer>
</esri:InfoSymbol>
<!-- visual stuff -->
<esri:Map id="myMap" extentChange="onExtentChange(event)">
<esri:extent>
<esri:Extent xmin="-125.9" ymin="44.6" xmax="-114.6" ymax="50.2">
<esri:spatialReference>
<esri:SpatialReference wkid="4326"/>
</esri:spatialReference>
</esri:Extent>
</esri:extent>
<esri:ArcGISTiledMapServiceLayer
url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"/>
<esri:GraphicsLayer id="myGraphicsLayer"/>
</esri:Map>
<mx:VBox width="260" height="100%" backgroundColor="#FCFCFC" fontWeight="bold">
<mx:DataGrid id="dg" width="100%" height="100%" itemRollOver="onItemRollOver(event)" itemRollOut="onItemRollOut(event)">
<mx:columns>
<!-- <mx:DataGridColumn dataField="Cities In View Extent" /> -->
<mx:DataGridColumn headerText="City Name" dataField="CITY_NAME"/>
</mx:columns>
</mx:DataGrid>
</mx:VBox>
</mx:Application>
