I am attempting to do calculations for a series of radar shapefiles using the Field Calculator. The ten shapefiles cover a total of five radars over two seasons. However, I am having problems doing the calculation for three of the five radars across both seasons. The field calculator operates the exact same way and I am using the exact same code across all radars. For the radars that I don't have calculations for, the Field Calculator just returns null values. I compared the results in the geoprocessing window for a radar that returned calculated values and a radar that returned null values, and found no difference between them. Essentially, ArcMap thinks it successfully completed the calculation for these three radars when it actually didn't.
Here is the code I am using:
[rosgeo_sine_fall_abs] / [EucDist_IL_radars]
What is causing this problem, and how can I fix it?
Thank you for your help!
