I've been trying to add a field that displays the coordinates of the points I created in AGOL. If I try to calculate the Geometry for x, it returns a number in the range of -17,xyz,xyz. The y is closer but still not correct for a UTM position in Hawaii. I noticed Geometry and Centroid return the same result. Is there a function to display the coordinate data in UTM or Decimal degrees on the attribute table of AGOL? Note: The points are in the correct place when displayed on the basemap.
