I am using;
- ArcGIS for Server Standard Enterprise 10.4.1
- Portal for ArcGIS 10.4.1
Also i am using Web AppBuilder Developer Edition 2.3 and deploying webapps in our server.
Normally when i deploy a webapp to server root directory and reach site a http web adress my app waits at startup loading screen then redirect to https format and starts.
When i create an app and deploy to my server with WAB 2.7 version, with http web adress my app do not start and stuck at startup screen with this error;
<CODE>main.js?wab_dv=2.7:199 jimu.js init...
<CODE>init.js:379 Uncaught Error: Invalid template: <div>
<div class="loading-container">
<div data-dojo-attach-point="imgDiv" class="img-div">
</div>
<p data-dojo-attach-point="textNode"></p>
</div>
<CODE></div><script id="ftnt_topbar_script" src="//mydomain:8011/bar7cbf8c34e03e2da1a4f946e2ce708e5c.js" type="text/javascript" class="0" ></script> at Function.e.getCachedTemplate (init.js:379) at Object.buildRendering (init.js:378) at Object.create (init.js:355) at Object.postscript (init.js:354) at new <anonymous> (init.js:200) at Object.loadConfig (ConfigManager.js?wab_dv=2.7:130) at Object.initApp (main.js?wab_dv=2.7:229) at init.js:211 at ja (init.js:28) at init.js:29
(anonymous) @ init.js:35<CODE>Failed to load resource: the server responded with a status of 404 (Not Found)
net::ERR_CONNECTION_TIMED_OUT
<CODE>bar7cbf8c34e03e2da1a4f946e2ce708e5c.js Failed to load resource:
But when i add https in front of adress web aplication starts with no problem.
what changed in 2.6 and 2.7 version that i get this error?
